Kubota L3302
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,612
2,077
Western MT
It’s a new model, so probably not. If you don’t mind me asking, why did you choose a 33 vs 39 or 2501?
Conda71
L3302
May 4, 2022
Wickham, NB
I have used my neighbours L3301 off and on for a few years and felt it was the proper size. The L2501 was too small.
Rdrcr
Vendor Member
May 7, 2021
740
894
WA
The L3901/L3902, L3301/L3302 and L2501 are all the same size.
Mike
SteveBX23
LX2610SU; BH77
May 23, 2021
180
305
South Jersey
A dealer I visited back in January had mentioned the 02 series having an increased lift capacity in the FEL from the 3301 and 3901. Not sure if true or not, maybe someone can confirm
jimh406
Jan 29, 2021
2,612
2,077
Western MT
Build my Kubota gives a LA526 as an option, so potentially more lift power. Since Kubota numbers are in Kilograms, it means it has 2.2 lbs more capacity than the one put on the 3301. Probably not a reason for many people to trade though. :D
Rdrcr
Vendor Member
May 7, 2021
740
894
WA
Additional lift capacity would be a welcome improvement!
Mike
old and tired
L2800 HST; 2005; R4
I would be surprised if it had more lift capacity.
When kubota changed where they measured the lift capacity from the L2800/L3200 to the next series. The LA 463 name changed to LA 524... (although it had the same lift capacity) after that, LA525 and I guess now with '02 series, LA526... It's just a model name change.
I set my tractor pressure at 2500 psi and couldn't be happier with what I lift...
Just checked; the pressure is (as it always has been on these "standard" models) 2350 psi (16.2 MPa)
They do list the L2501 as having 49# less lift capacity... also, anyone with a quick connect bucket that sticks out past the Pin On buckets, you loss even more capacity! (I got to look on the bright side since I don't have the quick connect bucket!!!)
gdillon
L2500, B2620
Jan 21, 2022
Missouri
I have aL3302 on order, dealer expects it arrive in the next couple of week. Anyone running one now?
I have one now. It has the LA526 loader and I added a grapple to it. I have almost 50 hours on it now. Plan to do the 50 hour service in a couple of days. I have been happy with our decision to buy it.
