Hi All,
I was hoping someone here might help me with a question I have about the 2 spool valve on my loader.
my machine (2002? I think?) has a Woods 1027 loader, this is a cab tractor so the valve is mounted to loader carrier frame and has cables running into the cab to the joystick. I recently mangled the valve with a stick that was picked up by a tire chain and broke the cap off one of the spools. it also broke where the spring is held off the end of that spool. this is probably repairable but I had been having other issues I think related to this valve: occasionally if I was running something off the remotes i would lose all hydraulic power and a noise would be coming from the area of that loader valve that sounded like a spool was loading up. if i shut off the remotes and fiddled with the loader joystick it seemed to release that pressure and work ok again. I have had similar issues with PTO power, which would get weak and seemed to be related to something in that loader valve making a very loud noise.
Anyway, this is all to say that i would like to just replace the entire valve with a new or rebuilt one, problem is they aren't very common. The valve is stamped as a HUSCO 46697, I'm hoping that it can perhaps be swapped out with a generic 2spool valve but I don't know exactly what I'm looking for, anyone else here been down this road before? any advice would be greatly appreciated.
Thanks!
Thanks!
