M6s-111
4,669
U codes indicate network communications faults. That code is lost communication with particulate matter sensor. The WSM should identify possible causes. Off the top of my head a bad sensor or wiring connection would seem likely.
5,248
1,927
spot on
I've had this happen. THe wires going into the muffler assembly were ate off by critters on the one I dealt with. Luckly replacing the differential pressure sensor also came with the wire I needed, easy fix in our case
