How common are broken SSQA pins?
jcwren
L4701HST w/ LA765, RCR1272, Forks
Jul 22, 2021
25
Clarkesville, GA
I had the lower left SSQA pin split in the center on my LA765 on a L4701HST. I found it when I went to do a 10 hour greasing. It was covered under warranty, but I'm curious about is this common, unusual, or totally unheard of? The service center guys weren't much help.
5,207
1,893
it happens on all brands and all types of equipment. not common but it does happen sometimes.
jcwren
Jul 22, 2021
25
Clarkesville, GA
Do you know what you were doing when it broke?
No. I did finally end up talking to the shop tech, and they think it was a manufacturing defect in the pin itself. I also haven't run the FEL very hard. I mostly use forks or a litter bucket for moving stuff around, and nothing so heavy that I've ever had the hydraulics go into bypass.
4,908
As a 'manufacturing defect', I'd want the OTHER pins all replaced. it could be 100s were made from the same batch of 'bad' steel.
jcwren
Jul 22, 2021
25
Clarkesville, GA
Why I don't disagree, there's no way Kubota will do that under warranty. Except for recall items, it's only warrantied when they actually fail.
This was the first time I've had any warranty work done on it. If another one fails, I'll replace it myself. They're about $24 online, and that's cheaper than having to pay even a discounted transport fee and have the tractor out of commission longer if they're busy. This time I was fortunate, they picked it up on a Monday and returned it Thursday. Driver said last year I'd have been waiting around 3 weeks.
forky
L2501 HST 4X4 8N
Feb 23, 2021
266
275
Wisconsin
That's not going to happen. Warranty is not going to replace parts that aren't broken. The dealer would not look forward to working with a customer that expects service like that....in my opinion.
B737
LX3310
Jun 9, 2019
2,024
2,200
Neil at messicks mentioned this in one of his videos recently. I didnt know broken SSQA pins were thing until his video. Just one of those things that are so simple you cant really think of a way for them to break... I believe he mentioned it was most commonly caused by the pin not being fully engaged.
Hue
Kubota L4060, box blade, stump bucket grapple, snowblower
May 17, 2019
87
34
New Brunswick Canada
I've had one split in half, it looked like only one side was getting grease. I'm guessing the difference in resistance created a shearing force.
FTG-05
Jul 21, 2013
282
115
TN
Andrew Camarata has had numerous failures of this type, mostly on exavators bucket pins. All have the same characteristic: a groove in the middle where it fractures. His fix is to install the grease fitting on the machine, not the pin itself and then replace the pin with a solid pin with no grooves.
jcwren
Jul 22, 2021
25
Clarkesville, GA
It looks like on the Kioti tractors that they put the grease fitting on the end of the pin. It's recessed to protect it. This seems like it should be less prone to breaking, and still leave the Zerk fitting protected.
