Like to know the story on this one...
5,711
yeesh I read it, and again...
sounds like they're clearing the trees out ,to put a big sewage line in...like 100' to the river ??
No one has a clue HOW to get the million dollars worth of machines out...hint: it ain't easy and WILL cost BIG..
Up here, you would need a zillion $$$$ permits to just begin that project ad that's after a 'archelogical survey' is completed.....and approval from 5-8 'boards'....
Please keep the info coming ! Going to be interesting to hear how they get out !!
8,237
Small update for anyone interested:
If they intend to dig them out, they will need to install a well point system, or Kelly wells around the equipment to suck out the ground water to dry it up.
If not they will just make soup.
Either that or walk in a crane on the pads.
Either way, it is gonna be $$$$$$ to get those babies out of there.
Hope they got good insurance.
3,226
A large barge crane was the answer…
5,711
funny, I was thinking last week... wonder if they got them out yet....
That's one HUGE 'barge crane'!!!!
I expect the excavators are now 'parts machines'.....??
Dieseldonato
Mar 15, 2022
728
439
Pa
Don't hold your breath. Seen some a few machines swamped pretty bad that they got going again. One down south. Guy was digging out a pond and got off the mats. Sank in till just level with the operators feet. Got another guy in with a big Volvo hoe to dig out the first hoe. Two step decks worth of mats, and a couple hours later they had the hoe dug out. Basically they hosed it off and checked over it and fired it off. Drove it out with the help of the Volvo. Only stuck for 2 days not 2 months. The stuck hoe was a rental. It did end up back in service. Happens more often then people think, just normally they don't get the publicity this story got.
5,711
up to the 'floor' isn't a problem, but at least one of these was TOTALLY submerged ! 2nd pix shows guy ON THE ROOF of the cab or engine compartment(well pretty sure...)
For sure ALL wiring , computers, electronics,gauges, etc will need to be 100% totally replaced. I suspect engines will be tore down as well as hydraulics (water gets in via the vents....)
motionclone
May 4, 2018
1,399
996
Maine
sounds like youre talking about letsdig. hes a pro for sure
