Anyone else have this issue? When the 3 point is up, I step off or on the tractor, the lift arms move some. Like maybe an inch or two. I checked the lift control for improper adjustment but all seems well. The control is bolted to the fender and the fenders do have some flex in them when getting on and off. I am just wondering if this is normal? Doesn't seem right to me.....L3560
Do you weigh enough that the tractor tires would spring up when you get off? LOL
I do not have an answer, but unless there is a reason, I lower my 3PH so the implement is on the ground before getting off.
And I never pay attention to the 3PH arms if nothing is attached.
Hopefully someone will offer a better answer to your question. Especially since I did not offer much help at all...
Edit: Hodge has a good point. Maybe something you are doing is causing a shift in the 3PH linkage...
