BX 3-Cylinder Turbo?
Dieseldonato
Mar 15, 2022
728
439
Pa
I think a half truth is the inverse of a half false...but I can't speak for Lugbolt... :ROFLMAO:
Well if it makes him feel any better, I did go and review some of my old training material, tier 1 emissions was what brought us common intercooler use. Not tier 2. Guess I found my false statement. I apologize. Quite a lot changed in diesel engines from the early 90s till what we have today.
Oil pan 4
L185 turbo
Sep 21, 2017
418
119
NM
Adding a turbo was definitely worth it. And I "never turned up the fuel".
3,091
Question - how did you plumb the oil lines to the turbo?
this is a VZ21 RHB31 Turbo Charger
Vigo
B6100, B8200
Jan 9, 2022
595
342
San Antonio Texas
Well, color me excited to come across a bunch of reading to do about a turbocharged Kubota 3cyl as i have B6100, b7100, b8200, and an appropriately sized turbo sitting around (among many INAPPROPRIATELY sized ones).
I tripled the wheel horsepower of a minivan by turbocharging it on the stock bottom end. I'm an ASE Master Tech, teach automotive at a community college, and have turbocharged multiple vehicles and cracked my share of piston ringlands along the way. 🤪 Maybe if i'd said that originally someone would have acknowledged what i said originally in post #11. You don't have to gain 'peak' power to gain power with a turbo. You don't have to add fuel. You will be able to burn your existing amount of fuel better than you currently can in certain situations. It will basically help you not 'bog under load'. Any time you lose rpm and your exhaust smoke darkens under load, that's when a turbo would do something for you on stock fuel.
By extension it also stands to be mentioned that anytime you can see your exhaust darker than the surrounding air, you ALREADY have more fuel than you're burning, which could be burned with the addition of a turbo. You also have to consider that it takes more fuel to make power under load at low or mid rpms, then it does to have the engine sit at the governor rpm with no load. If you just rev your engine to max rpm with no load, you are only giving it enough fuel to spin the engine at that speed (but not put out much power to the end of the crankshaft). There is much more fuel available then what you're using in that situation. The only time you are actually using all the fuel the stock injection pump will deliver is when you are LOADED at max rpm to the exact right extent that you are staying at max rpm, and not bogging from the load, and your exhaust is still 'clean' (not dark). That's balancing on the head of a pin (ie basically never happens)! At all other times, there is more 'stock fuel' available than what you're using, and you could use some of it if you had a turbo. So all this stuff about adding fuel i think is tinged with some misunderstanding.
Oil pan 4
L185 turbo
Sep 21, 2017
418
119
NM
Yes, but you did it to recover power loss due to altitude, if I recall correctly.
It will put my 19.5hp gasoline powered mower to shame. I don't get hardly any smoke now so it burns everything. Only time I see smoke is on startup and when rapidly increasing revvs.
Dieseldonato
Mar 15, 2022
728
439
Pa
There's plenty of info available on turbo charging 3cyl kubotas, and yanmars. They are some of the favored engines for diesel garden tractor pulling. The d1105 also comes with a factory turbo option. There is tons of options for that engine in particular.
