B26 Broken Gear Teeth in Right Rear Differential Housing
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,063
1,511
Pittsburgh
Something is going on there. I have no idea what but you should've broken the left side by now.
Pau7220
Aug 1, 2017
785
279
Scranton, PA
This will be the 3rd time I've replaced these parts on the same side.
I’d be looking very closely at the case and axle housing for hairline cracks that holds the bearings in place which holds those 2 shafts parallel. If those gears are actually pushing themselves away from each other and loading the tips of the gear, that would also do it.
jallen4888
B26 Backhoe
Jan 1, 2020
Whitesburg
I find it to be really strange that nobody has ever complained of breaking the left side. Don't you think that's odd? I've read everything I can google about this issue, and no "left" side issues come up.
jallen4888
B26 Backhoe
Jan 1, 2020
Whitesburg
Edited: We've looked for cracks, or excessive play in the gears. It's beyond me.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,063
1,511
Pittsburgh
Is the pinion and bull gear the same part number for the right side and the left side? If they're interchangeable then it makes it tough to blame on a bad batch of components.
If they are different then that's my first suspect.
DDIBON
BX23, B26, loader, backhoe
Jan 26, 2021
Terlingua
My first posting. Am using a 2021 Kubota B26 TLB with 460 hours. All routine service and maintenance performed using Kubota products.
I experienced the same issues described above during routine use. Routine use for me is moving gravel and sand, digging trenches and using pallet forks to move materials.
On a routine day I experienced a clunk from right rear side. Tractor was then loaded onto the trailer and not used.
The dealership found shredded metal exactly like the posted photographs. A quarter sandwich bag of metal fragments was also collected.
Kubota and the dealership treated me well. Yes, it took a few months and it is a giant economic hit and pain in the ass to pay on equipment I couldn't use.
I have no need to use a differential. Four wheel drive yes. Have not experienced any shock loading. Yet, I experienced this same issue.
All of the parts, bearings and other pieces were replaced with new materials. Kubota initially held a position that I somehow had to have been using the differential locked, whether I realized it or not.
Thank you to our mechanic, who after warranty work was declined took it upon himself to contest Kubota denial of warranty coverage.
I always used Kubota products. That helps A LOT! I kept routine maintenance records as well. Also, the mechanic knew exactly where I use my machine and fully grasps no need for differential use exists for me ever.
So he photographed the differential lock that still had new paint on it without scratches or heel marks. He showed them how well we kept the machine greased (I e got grease smears all over my machine). And despite all routine service being done myself (I am 120 miles from any service) he showed how all work was done with Kubota products.
Kubota listened to him and covered the full repairs.
However, when I got home and unloaded the tractor I noticed it felt differently. When I turn right or left the rear wheels tend to push the front wheels so that turning is not smooth. A small lime of gravel builds up on the far edge so that if I turn right a line of pushed up gravel exists on the left side of the tire tracts and if I turn left it leaves a ridge on the right side.
This remains the same in two wheel or four wheel drive. It has never happened to me before. In an extreme situation it seems like it could roll a tire off the rim.
I do not know how to trouble shoot this issue. It has to be related to the complicated repair work that was performed.
Does this group have suggestions? I really hate to drive this back up for adjustments I could do myself. It's the weekend and I cannot reach the mechanic.
Could front tire toe affect this? Has the differential somehow locked even without me using it?
So, I've parked the tractor and written this note to the group. I've had it back in my possession now for less than 23 hours. Straight ahead driving is fine but that is unreasonable. I am not using it.
On a larger note, would people in this group keep a tractor with this history? I am barely not upside down on the note. I use it 10 to 20 hours a week. The B26 TLB suits me, but of course I would love a larger machine, like the L47 TLB. But mostly, I just want a working machine without the nonstop risk of it dieing and leaving me with something I cannot use while paying off a note to Kubota.
Thanks for your time. When it is solved I will post the solution.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,063
1,511
Pittsburgh
Using your backhoe stabilizers get the rear axle off the ground. Then spin one rear tire by hand and see if the differential is free. Feel for binding through a few revolutions.
DDIBON
Jan 26, 2021
Terlingua
Will do. It'll have to be in the morning. I will make sure and give follow up.
PlainRamenNoodles
Kubota B26
Jun 2, 2023
Starks, Maine
Hate to pile on but this is exactly the same issue I'm having. Right side diff/brake gear pin is shredded.
In the WSM, it does show that the two sides are not symmetric, with the right side pin being longer than the left. Dunno if that's actually the issue but whatever.
Mine seems to have broken because oil was just pouring out of the loose drainage bolt at the bottom of the axle housing. It got too hot, looks like the metal in the casing crazed a bit, and there's a hairline crack along the bottom where the bearing for the bigger gear sits.
I get that replacing the differential case is what I /should/ do, but that's $700 that I don't have right now. My plan was to JBWeld (or whatever doesn't dissolve in utf) the crack to at least keep the oil from leaking. How terrible an idea is this? Probably better to just leave it and accept that it will need another repair? I just worry about how little time this repair (replacing $200 pinion) is going to buy.
Glowplug
11
Pennsylvania
Those of you with a B26 that have had issues with the rear axle case, have any of you done the work yourself? I have a B26 and while it doesn't have this problem the rear axle seals are both leaking and I would like to fix them myself. Just getting to those seals requires removing the backhoe and loader and subframe and it's all rather tricky. (Probably most concerning is removing the subframe) Just looking for someone that has done that job before and can at least comment on oh how difficult it is to actually get to/remove the rear axle housings. Thanks
dholt53
21
Gasburg
Yep… I had a Randall knife brought back from Vietnam and my Mom (rest her soul) managed to do to it what a year over there couldn’t… managed to put a chip in the blade trying to dig something out of a shower drain-grate.… when a common screwdriver would have removed the 2 screws holding the grate. :(
This is my 3 rd B26 and used them hard. Never had this problem. When I bought this 2019 at auction. The rear was bad because they ran it with the brake on and rung the teeth of the shaft. I don’t use the brake for fear of this. This weekend I had to used the diff lock to go through some red mud. I stopped and stepped on the diff until i felt it connect. The next day I felt the rear end Skip a tooth. Took it apart and a tooth was missing on the big gear and shaft torn up. I rarely use the diff lock and always go easy with it. iam The only operator. When tearing it down I found small pieces of metal . I may have missed them last time but hard to clean everything in the trans . Good luck. Dave
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
Sorry for your troubles. Hope you find the root cause because we rely on our B26. There is some skill in setting up a ring gear contact patch. I’ve watched but never done.
Plumberman
B26, VIO17
May 21, 2025
Northern KY
Having same issue on my 2013 B26 at 1420 hours. Original owner and have used it much more aggessively than I was when issue happened. I don't recall anything popping or loud noises, just a clicking, skipping sound developed when backing up in 4wd. You can actually see the right rear tire skip just a touch once every revolution. Also makes a clicking sound that corresponds with the timing of the skip. Have not torn it down yet, as I wanted to do research first and see if there were any known issues. Looks like I found it. Thanks for everyone who has posted, I really do not want to tear this thing down for nothing only to find out it was something more simple. Will post when I get into it. I will have to agree that with everyone having same issue I suspect an engineering design flaw. This is certainly a weak link in the drive train.
