This particular problem seems to show up in every instance as the right rear.
I've not heard of anyone having this issue with the left rear.
Had to replace right rear differential gears about 3 months (40-50 hours) ago and I'm broken down again. I'm not sure if my mechanic replaced the bearings also, or just the gears.
Does anyone know if this is a manufacturing defect that is causing the initial failure?
I do not use the differential lock, but I do keep the unit in 4wd.
Thanks in advance.
Thanks in advance.
