BX2822A 55" Commercial Snow Blower - DO NOT purchase BX2821A hydraulic deflector kit if you have a third function. Do this instead . . .
5,157
Does anyone have a PDF of the parts breakdown and description page of the BX2821A? I am considering doing the same with my BX23S, and the parts breakdown and description page will help me decide exactly what I will need in addition to parts that I already have. I have a cylinder from a plow that I can use, and I had made a similar modification to my old snow blower back around 2006, and I still have the cylinder from that unit.
thisplace
BX23S and more
Apr 23, 2022
UT
So I want to hydraulically articulate the chute deflector on my BX2822A 55" commercial snow blower with my B2601 tractor TRUE THIRD function.
I can't see paying $1100 for the hydraulic chute deflector kit BX2821A when all I need are the parts highlighted in red. If you purchase the kit, you are purchasing parts that you really don't need if you have a third function. You will be paying for a diverter, electrical harness, etc, all you don't need, and WORST YET another switch up on the joystick in addition to the 3rd function. YUCK!!!!
The dealership confirmed that the hydraulic chute deflector kit for the snow blower includes extra items you do not need if you have a third function on the tractor. It includes electrical connections and a diverter system that are unnecessary.
The dealer priced the actuator only and the mounting hardware at $560, which would save me $500 over the full hydraulic deflector kit.
In the picture below, the person paid for the diverter on the blower and the dealer came out and hooked the deflector directly to their tractor third function.
Borrowed picture from someone kind enough to show me the clean setup.
STILL WORKING THIS ISSUE TO GET THINGS HOW I WANT THEM. THIS SETUP IS PERFECT!!!! CLEAN AND ONLY ONE BUTTON ON THE JOYSTICK.
I wanted to give you a HUGE thank you davidmem!
I bought a BX23S-1 in Dec. 2021 and it arrived in early Mar 2022. I ordered the 48" snow blower (BX2830) but did not order the blower kit (BX2821A). Later I found this thread and ordered all of the parts on your pdf examples except for the hydraulic cylinder and paid $230 from my local dealer. They wanted $540 for the cylinder but I found it on Messicks for $423 and in stock (saving $117). Once I got the parts and started installing it, I realized that I my cylinder came with the attaching pins and I could have saved around $50'ish not buying those, but they might come in handy later so I'll keep them. I also realized that I didn't have the bolts for the hose clamp and support clamp which I'll have to get later. But most of it is installed. So without hoses the cost for me was around $680 (ship+tax,etc).
davidmem can you tell me how long your hoses are? The pdf just says "1 set hyd hoses". Once I get the hoses I can attach the 90 deg elbows, but I'm not doing that now since the cylinder holes are currently plugged and would not be if I installed the elbows, so those will be done when I get the hoses. So the hoses and flat face connectors will raise up the final price but I'm happy.
Again, a big thanks for this info, it saved me a lot. Here are some pics of my current install.
davidmem
Soon to be owner of Kubota B2601 Toro TimeCutter Model 7577
Mar 14, 2021
179
79
Bethany, CT
Awesome!!!! Very welcome and I'm glad it helped you. I will try to remember to measure the hoses and get back to you. I'll try tomorrow.
BadAndy
BX23s TLB-BX2822A Snow blower-LP BB-HLA Forks-Craftsman YT4000 Lawn Tractor
Mar 30, 2021
80
80
Hi Guys, I am in Canada and have looked for the hydraulic cylinder, the specs call for a 2" bore 5" Stroke cylinder. My dealer quoted me at 700.00 for that cylinder which defeats the savings of not getting the whole BX2821A kit... It's hard to find a 5" stroke cylinder... I did find a 2" bore 6" Stroke cylinder for 90.00... I am not a hydraulics guru but would I be able to adapt for the 1" difference? huge difference in pricing as you see below
Dealer cost all parts except hose: 908.99 (5" stroke Cylinder)
My DIY cost all parts except hose: 302.52 (6" stroke Cylinder)
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
282
Bigfork Minnesota
Here is what I did to get hydraulic chute deflection on my front snowblower. Maybe it will give you some ideas.
davidmem
Mar 14, 2021
179
79
Bethany, CT
I wish I could give advice here but I can't. I wonder how much the kit is now if the cylinder is already up to $700? If the kit is $1,500 it still might be worth the savings.
BadAndy
Mar 30, 2021
80
80
Thank you Deep Woods, looks like your cylinder is a 6" stroke as well. Good idea for the fit, I will definitely look at your idea. :)
BadAndy
Mar 30, 2021
80
80
Thanks for the reply David, I think I will try the 6" stroke cylinder and adjust like Deep Woods did.
5,157
As long as you have the stroke long enough to work, the extra length just won't be used. It isn't likely that the extra 1" is going to make any difference. The Kubota cylinder is a standard cylinder that they use on many products, such as snowplows, snowblowers, sweepers, etc. It is extremely overkill for the items that it is used on.
DeepWoods
Apr 10, 2019
342
282
Bigfork Minnesota
Just be sure you use the entire stroke when you figure your geometry of you brackets or you may end up bending something if your range of movement isn’t enough for the length of your stroke. 😉
Downeaster
Kubota BX1880, loader, mower deck, and ballast
Oct 18, 2022
197
81
Waterford, Maine
Agreed, and this is partly because it includes many parts you do not need if you have a third function on your tractor.
I am actually thinking about buying the BX2821a kit. I have a BX1880 with a BX2816 snowblower. Everything works fine, but I don't like the hand crank I have on the side, and I don't like having to get of and adjust the up and down on the top of the chute. I need a little help in knowing about the bx2821a kit. Does it replace the Bx2818a, and BX2820a. It looks to have the deflector for the chute top, that raises and lowers the snow stream. Does it rotate the chute right and left as well, and I assume it has a 3rd function as well for all this. Somewhat confused in my old age. Thanks.
bensmind
Minnesota
I'm in the process of following this thread to use my 3rd function to drive the deflector without buying the diverter.
The reason for the kit with the diverter is that it drives both the rotation and the deflection off the same hydraulic lines. It's effective a poor man's 3rd function. Which for you sounds like the right thing.
I am curious if anyone following the thread could post what length hydraulic lines you went with. By my measurements it looks like 120" minimum, probably more like 132" or more to allow for chute rotation. I'm also curious on line size, Kubota specs 1/4" but it's clear from the pictures in this thread people are using much larger lines and adapting down. My 3rd function is setup for 3/8" so I would be fine with that but then would need to choke down to use the 1/4" 90° swivels from the kit.
For anyone interested I've attached my Messicks parts list, note that some of the 1/4" hardware isn't necessary (the things with a 2 qty)
bensmind
Minnesota
I second this, I started going down the path of designing a bracket that would accept a more standard 6" stroke cylinder and decided it wasn't worth the hassle. The geometry is very specific. Without modifying the chute as needed or modeling the actuation far beyond my ability I wasn't confident I would get a good result.
Downeaster
Oct 18, 2022
197
81
Waterford, Maine
I called Messicks, and it only does the top of the chute deflection. Too much money for that. Over 1500 dollars.
