I have a V2203 diesel generator. I haven't owned it that long, and it ran good when I got it. It recently developed an issue where it starts fine and runs perfectly for up to 2 mins. Then the fuel solenoid shuts it off. If I try and start it immediately, it will attempt, but the fuel solenoid shuts off. If I let it sit for an hour, it'll start just fine and run for a minute or 2 and then the solenoid shuts it off. I've replaced the solenoid, lift pump and temp sensor. Nothing has changed the behavior.
I have also observed that the 12 volts to the solenoid is not being disrupted when the solenoid closes. The solenoid just shuts the motor down and a few seconds later a relay turns off the 12 volts to the solenoid. Something is shutting down the solenoid, but it doesn't to appear to be a lack of 12 volts.
Ideas? Thanks.
Ideas? Thanks.
