Condensation inside instrument panel Bx1870
stjohnben
Bx 1870
Apr 17, 2022
Anyone experiencing this problem? Is there a recall bulletin? The problem is the moisture caused corrosion and ultimate failure of gauges and connector of original panel and also 100+$ replacement panel
2,551
Common problem - some have pulled cluster, repaired connections, some have replaced the unit too.
Is this getting rained upon?
RDinNHandAZ
Kubota BX1870, FEL, BX5450 Snowblower, back blade, customized snow cab
Jun 26, 2022
89
105
Lakes Region NH and Sonoran Desert AZ
I need a panel. Not because of water AFAIK. The signal wire from the alternator is good, the hour meter and all the lights and other gauges work, no moisture inside, clean connector and it is corrosion free but the tach does not work. A new one- (PANEL, METER, Part # K2731-62510) is $273! I just wanted a working tach not to send it to college! Is there anyone who repairs them? Anything used? If I replace it does the hour meter stay correct?
Boatman
Kubota L2800, Kubota BX1870
Nov 26, 2016
168
54
Mill Spring, NC, US
After seeing condensation in mine.... I drilled a couple 1/4" holes in the rear lower edge. Then duct taped a small desiccant pack over the holes. Haven't had condensation since.
