Ackman
L6060hstc cab, WoodMaxx 78HM flail mower, EA Land leveler, 78" EA Box Blade
Remove the hose, remove the 90 degree fitting, install flush-type pipe plug.Anyone know of a thread that addresses the terrible weld quality on my 2018 BH92? The amount of oxidation is completely ridiculous compared to everywhere else on my tractor. Granted I live in heavy salt air but I don't see any degradation that compares to this.
OSPHO.... BEFORE..... repainting!Wire brush and orange paint, save what you can.
Looks like a classic case of a galvanic couple. The bung might be a standard 10XX (mild) series steel and the elbow looks like it's stainless steel. As was mentioned, nothing wrong with the weld.Anyone know of a thread that addresses the terrible weld quality on my 2018 BH92? The amount of oxidation is completely ridiculous compared to everywhere else on my tractor. Granted I live in heavy salt air but I don't see any degradation that compares to this.
When are you going to post a picture of these "crumbling welds"?Thank you all for the help. Hopeful - but not optimistic- I can get the elbows replaced without removing the rest of the crumbling welds.
Never seen it on Kubota either. Makes me wonder a lot of things.Thank you all for the help. Hopeful - but not optimistic- I can get the elbows replaced without removing the rest of the crumbling welds.
I visited a buddy who has a 30 year old Woods backhoe. His welds and fittings are pristine- paint is faded but not a drop of rust or corrosion anywhere. Arrrgh!
Agreed!When are you going to post a picture of these "crumbling welds"?
I'm sure we'd all like to see them.
I'm going to be picky here because I had a career replacing zinc plates on vessels as a diver/welder and a career in a corrosion lab as a research engineer. This is a galvanic couple with direct contact between the bung and elbow with the bung acting as a sacrificial anode. A battery stores energy and there's no storage of energy in this case so it's not a basic battery.yup... basic battery.... 2 disimilar metals(ss + Fe) and electroyte (salt water)
Your environment is the reason, not the PTFE.My L47 has pipe wrap tape on every hydraulic fitting going into the rams, not one bit of rust, helps that I live in the driest place on earth, wonder if that helps keeping the different metals from touching for electrolysis?
Just a simple question, but don't you need a conductive liquid of some type for the galvanic action to take place?I'm going to be picky here because I had a career replacing zinc plates on vessels as a diver/welder and a career in a corrosion lab as a research engineer. This is a galvanic couple with direct contact between the bung and elbow with the bung acting as a sacrificial anode. A battery stores energy and there's no storage of energy in this case so it's not a basic battery.
Zinc plates on steel hulls of ships work in the same way. The couple is immersed in a salt solution in the case of ocean going vessels, and the zinc plates are consumed preferentially to the steel hence the term sacrificial. In both cases, the active metal drives the potential of the more noble metal above it's pitting potential thereby protecting it.
By the way, the noble metal in the couple drives the potential of the less noble metal below it's pitting potential. This is why many water utilities select specific alloys to hook up to your homes water supply. They have no problem with your pipes and fittings being sacrificed, but have no intention of there's doing the same.
You do, and the OP mentioned living in an environment with lots of chlorides so he must be near the ocean.Just a simple question, but don't you need a conductive liquid of some type for the galvanic action to take place?
If so, would the poor performance of the paint be the root issue, since had the paint remained intact, there would be no path for a galvanic loop? Unless the paint was conductive I suppose...
Similar issue occurs with electrical terminals when using (dissimilar) aluminum wire.Just a simple question, but don't you need a conductive liquid of some type for the galvanic action to take place?
Just asking, because I remember being in a meeting (couple decades ago) with various disciplines, talking before the meeting started, and galvanic corrosion came up, and being electrical, I asked the metallurgist why brass valve fittings can be used with black iron pipe (or something similar) and he simply said, there is no liquid involved...(I remember the part about the liquid, forget the other details actually).
In the example with the ship, the seawater is the liquid. With the OP's tractor, I guess it would be rain, or excessive washing of the tractor...the tractor does look pretty clean! LOL
Being a bit picky again, it might appear that no liquid or electrolyte is present, but there has to be in order for corrosion to occur. High humidity (in excess of 70% R.H.) combined with sulfates and/or chlorides from outgassing from the battery, the enviroment etc., form the necessary electrolyte, even if not obvious. In order for electrons to move, ions have to be present in an electrolyte.Similar issue occurs with electrical terminals when using (dissimilar) aluminum wire.
Absolutely no liquid is present, but without NOALOX treatment, the aluminum wire (dissimilar metal) will corrode, until it becomes disconnected, often causing a fire.
"picky"?Being a bit picky again, it might appear that no liquid or electrolyte is present, but there has to be in order for corrosion to occur. High humidity (in excess of 70% R.H.) combined with sulfates and/or chlorides from outgassing from the battery, the enviroment etc., form the necessary electrolyte, even if not obvious. In order for electrons to move, ions have to be present in an electrolyte.
