Bultra b1-17
bultrab1-17
Bultra b1-17
May 11, 2012
12
canada
I have a grey market kubota and when i push a little hard it seams to get diesle in the crank oil ? Does this mean i have a worn out engine?????:confused::(
kuboman
721
No, it means you have a seal gone in the pump or maybe even just the lift pump is leaking back into the engine. I would start with the lift pump, cheaper and easier to repair.
bultrab1-17
Bultra b1-17
May 11, 2012
12
canada
Ok, i am not sure what a lift pump is. I do have a shop manual for my b7100. I hope it will give me the info i need to fix it. Thank you very much for your help.
kuboman
721
It is the mechanical or electric pump that supplies fuel to the main injection pump. Yours will be a mechanical one. Usually attached to the injection pump. Just follow the fuel lines.
bultrab1-17
Bultra b1-17
May 11, 2012
12
canada
Well the pump was'nt the problem. but i did notice that the air vent screw was left wide open and was that way when i bought it. do you think this would contribute to the diesel getting into the oil? i shut it off and the tractor runs just fine. if not could you advise me on how to deal with the seal in the pump? that would be the injector pump, if i am correct.
PS.the air vent screw is located on the top of the injector pump.
kuboman
721
I am surprised it ran hardly at all with the vent open. How do you know you are getting diesel in the oil.
bultrab1-17
Bultra b1-17
May 11, 2012
12
canada
When i check the oil the level is way up the dipsik. i fill it to the proper level and when i check after use the next day the level is way up again and the oil is thin and runny.:confused:
What els could it be?
bultrab1-17
Bultra b1-17
May 11, 2012
12
canada
So here i am at 2am, cant sleep. i'm now thinking is it possibly hydrolic fluid leaking in from the pump seal?.:confused::eek:
hodge
Nov 19, 2010
2,945
509
Love, VA
Smell the oil- do you get a diesel odor?
You could also have an injector sticking- how does it run? If it runs smooth, that probably isn't it. But, you need to get this fixed- running it with diluted oil is going to kill the engine and the injection pump. And that is going to get ultra expensive.
kuboman
721
Ahh....bet it is the hydraulic pump seal. More come problem than diesel in the oil. If it is diesel you should smell diesel in the oil. You should smell hydraulic oil too.:D
bultrab1-17
Bultra b1-17
May 11, 2012
12
canada
Thats just it, i dont smell diesel so i am asuming it' s hydrolic fluid. i will remove the pump today for inspection. Thanks for all your help, this is :)a lot of fun and i hope i get corrected.
bultrab1-17
Bultra b1-17
May 11, 2012
12
canada
Hey, hodge, i have a b7100 hst as well and it has lots of hours but still runs fantastic. love that tractor as well but wish it had a loader insted of a snow :rolleyes:blade.
bultrab1-17
Bultra b1-17
May 11, 2012
12
canada
Well i fixed the problem. it was the hydrolic pump. have to replace it because it is wore out and putting pressure against the seal. the pump cost just under 500.00 bucks :eek:
I was able to use the pump from my b7100 hst. ordered another one for it. again thanks for all your help.:)
