Home made ballast weight
Hkb82
Nov 17, 2021
418
330
Ontario Canada
Thought I’d post a rear ballast I made for my 7060. Added some chain tubes to the inside and filled with gravel till I do a concrete job then I’ll fill it with that.
Weight unknown???
Reactions: 9 users
2,888
Damn nice - almost looks like a super grill!!!
What's it weigh?
5,157
Concrete will cause the steel container to rust out in a few years. Bad idea to use concrete with thin steel barrel.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
Ya I’m kinda thinking that it will rust no matter what and if that’s the case I’m still left with a good ballast block.
OrangeKrush
Nov 15, 2020
1,044
517
Indy
Nice.. I like the Kubota touch!
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
9
Columbia, CT
Nice set-up! 1st pic looked like Kubota Smoker/Grill!
Hkb82
Nov 17, 2021
418
330
Ontario Canada
Joked with my buddy that it was a cooler for the back and I’m building the smoker for the fel.
WFM
L3800
Apr 5, 2013
1,524
971
Porter Maine
Its very gratifying to make something usefull and cool.
Weight wise I'd guess 700 lbs.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
Well it’s 10 cubic feet of volume and I think cement is around the 150lbs per cubic foot so if it was full of cement it would be around the 1500lbs. Being that I used gravel I have no clue but it feels like more then 700lbs.
Anvil HB
B2630 LX2610
Jul 29, 2020
15
11
Ocala Fl.
Very nice Fab work. The use of some U-channel edge trim, and the chain tubes and your fit and finish are are Great Features. If you do remove the gravel and go with concrete, you could add some Roll on bed liner to help slow any rust issue over time.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
I coated the insides with 1.5l of white tremclad but truck bed liner may have been a better option. The most time on this thing was the 3ph bracket so if it ever did rot out and I’m still using gravel those tanks arnt hard to find. I actually have another one kicking around.
I’d also love to get one of those logging 3ph attachments for skidding logs so in the future that may become my rear ballast.
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
I always get a chuckle out of subjects like this. I was talking to my coworker the other day about tractors and he said his old John Deere will still be running after my Kubota is long dead. That's a debate for another day, but I asked him, "Does it really matter?" He gave me a funny look and I said, "It only has to outlast me as far as I am concerned." So, the real question is, how long will it take to rot out your ballast tank? :unsure: :ROFLMAO:
South 40
L1500DT, 750 Ford backhoe, 49 D4 Cat Repowered with 6.9L Diesel
Nov 12, 2012
168
53
Bloomsdale, Mo. USA
Put a rod the right size for your 3pt all the way thru it then concrete, that way if and when the barrel gives up you still have a weight ready to work without missing a beat, :)
Samantha
