3pt skidding / logging winch like a Hudson or farmi or something would help sort of…however they would drag the logs and you will still have the previous problem… I demoed a Hudson and it was awesome in terms of pulling power, however it drug the log until you get it to the plate to lift up…then it drags the butt, unless maybe you had an arch. I think a log arch might help but would not be able to drag the log if unable to reach it. I try to drop tree so that I can grab from side with forks or grapple and then place in the wagon(avoid dragging where possible). When space doesn’t allow that then I chunk It up where it falls and then Haul with loader / wagon or atv / trailer…I try to reduce dragging for reasons you mentioned. If cold and snow I drag to convenient location. I have a log rack that I can fill with logs and then make repeated cuts quickly…that in itself helps speed things up but that involves hauling all the logs to the rag. However with my B and snow on ground I am limited in weight / traction. Personally I would not invest in a logging winch for the B. I think it would be safer and more bang for the buck on a larger tractor….(if I only had the b and process as much wood as you mentioned, then I would have a winch for the B-logging winch is awesome. so far I have failed to gain any sort of commitment for my wife to work more to pay for a winch for MX. I do use a portable winch from my FJ to control dropping trees from time to time, but I do not use that to drag the trees as mentioned above. I think a second machine either way would be helpful?
