So I finally got my tractor back after fixing a engine oil leak under warranty, installing a 3rd function, and purchasing a new LP grapple. Right after delivery I checked all the fluids, moved my bucket with the grapple, parked it and went to the dump. Once I got home I started playing around with the grapple and moving some brush. After about three small loads of brush and moving a rock I hopped off the tractor to move something by hand and noticed a hydro fitting was spewing out fluid. I tightened it and then checked my fluid which was significantly lower than when i initially checked it earlier after delivery. I added fluid and got back to work. Not long after the same fitting started leaking again. Tightened it and went real easy getting a lil more brush and the same damn fitting was leaking again. At this point i was pissed, took off the grapple, on goes the bucket and clamp on pallet forks and back to work I go.
First do any if you know why this same fitting keeps on leaking?
Second what would you say to the dealer? Explain the situation and let them fix it or tell em take it back and try n get a refund?
At this point I am beyond aggravated because I will lose at least two days of work when I have already been over two for my tractor to get back to me.
Sorry for the long post and looking forward to your thoughts.
