New B2601. Thanks for the advice!
keith204
44
42
Missouri
My main concern was stability. Though wider, it's quite a bit taller than the BX I had previously borrowed.
But, I think the R4 tires must help quite a bit. They don't have any bobble/wobble (bwobble?), and I feel quite a bit more stable w/ this machine.
Also, per your advice I got the 5' box blade, which this machine handles - teeth down - no problem.
Floating bucket mode is amazing. Never seen that before.
Thanks for all the advice and helping me choose the model.
Reactions: 12 users
tractorX
KUBOTA L2501 DT 5' BOX BLADE 42" FORKS PIRANHA TB 5' BUSH HOG 6' GRADER
Sep 27, 2013
81
79
Rock Spring GA.
great pic of the tractor and family! your young'n has got that, "do we have to" look on her face☹
congrats!
Rdrcr
May 7, 2021
670
738
WA
Congratulations!!!
Mike
Quick
B2601, LA435, BH70, LP SGC0554 Grapple, LP RB1672 Rear Blade, King Kutter 60" BB
Sep 23, 2021
142
249
St. Clair, MO.
Nice looking tractor and family! (-:
Congrats!
trueg50
60
77
Vermont
Got the tractor just in the nick of time, you're youngest will just about fit on your lap for another summer (maybe two). I only have mine on my lap for very flat/safe work and if I push back I can have her sit on the seat between my legs and get the belt across her and I. She can just barely fit on my lap now and sets her feet on the hump.
I won't scare you with the story, but even if the tractor is off, if someone hits a lever that operates a hydraulic line it can drop the implement. I drop my bucket and 3 point (usually box blade) when I'm done with the tractor just in case someone/thing hits the levers.
RalphVa
738
320
Charlottesville
Hope yours as stingy on fuel as our B2601: 0.36 gph through to near 28 hours. WAY lower than the 3 JDs I had and almost as low as the small (12.5 kw) Isuzu.
B737
LX3310
Jun 9, 2019
2,024
2,200
please stop polluting the forum with this nonsense, you are not getting 14 hours of actual work per tank out of a B2601. Because you are putzing around your driveway at idle, does not mean 'facts' :rolleyes:
RalphVa
738
320
Charlottesville
please stop polluting the forum with this nonsense, you are not getting 14 hours of actual work out of a B2601. Because you are putzing around your driveway at idle, does not mean 'facts' :rolleyes:
Do not need comments like this. I'm using this tractor the same way as I did the 3 JDs. Its fuel usage is about half what the JDs used.
B737
LX3310
Jun 9, 2019
2,024
2,200
I didn't mean to hurt your feelings.
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
333
97
Ottawa, ontario
I have to agree on the fuel usage. Had an old Bolens H1502 and the 2601 hardly uses anything compared to it. Never thought I would care about amount I use but as the price of diesel goes up I'm glad to have it.
D
Deleted member 47704
Guest
Kubotas seem to be good on fuel no matter what model, our R540 loader has a 6 gallon tank and runs for a long time on a tank.
