2003 TLB L35 BT900 Backhoe Hydraulic Thumb
RaleighL35
Kubota 2003 TLB L35
Mar 30, 2022
Raleigh NC
I wanted to share my latest project on the L35. I could not find anywhere on the internet where someone else has attempted this type of thumb installation. Long story short, I Frankensteined a way to add a hydraulic thumb that is as close to a factory option as possible when it was never offered by Kubota for the BT900. I did not like the idea of an aftermarket spool valve with hoses hanging all over the place.
I was able to find a Husco sectional valve 5002-A1 on Ebay to add to the controls. I noticed all the holes were already made for the section to be added. ($150)
There was even the three holes to install the foot pedal control. I sourced all the pedal control parts for a BH92 backhoe. ($375)
The thumb is from Gentec and is part number HT824. ($1200)
I then took the tractor to a local hydraulic hose shop, who were able to custom make all the hoses and fittings for me. ($500)
This project seems expensive but is worth it in the long run. This tractor has served me well and I have no plans of replacing. See the pictures to show all the details. Hope this helps anyone that is considering adding a hydraulic thumb.
3,646
2,239
Nice!
6,774
Nothing Frankenstein about that!!!! My hats off.
L35
Jun 13, 2010
683
787
CT
Man that’s awesome, nice job. How in the world did you fit 2 more hydraulic lines through there is what I need to know haha!
5,188
VERY NICE WORK!
I have a professionally built custom thumb on my 2006 L48 TLB.
Yours looks every bit as nice!
You are likely already wondering how you did without it for so long.
I think $2225 is fine for total expense.
The original owner had mine custom made, and installed by the selling dealer ( combined with an excavator style Q/A BH bucket coupler ).
I would not be at all surprised if the cost for mine was twice your cost,.... and that being in 2006 dollars.
3,646
2,239
I had the same thought. Maybe 1/4" lines? I suspect he routed them outside the swing joint. I'd been thinking about using a diverter mounted on the boom to avoid more hoses through there, but this looks slick.
3,646
2,239
Now you've got me thinking about adding a section to my loader valve to get a third function. The Messick's part numbers lead me to believe it uses the same type Husco valve. I'll have to check it out next time I'm down there.
RaleighL35
Kubota 2003 TLB L35
Mar 30, 2022
Raleigh NC
I did use 1/4" lines routed thru bottom boom. It is snug with all the lines, especially with all of em covered with nylon protection. No problems thus far. Have used the thumb a lot and love it.
3,646
2,239
Thanks for the feedback.
L35
Jun 13, 2010
683
787
CT
UPS dropped off something today 😎
L35
Jun 13, 2010
683
787
CT
Regarding the install......
Pics, or it didn't happen! (y)
I’m basically using the Raleigh L35 method just with a couple home made parts to save a few bucks, his was so flawless there is no need to reinvent the wheel 😉
Coyote Shadow Tracker
MX5400, LA1065, BH92 Hy Thumb
Aug 6, 2024
46
Georgia
Would like to know more about this modification. We purchased what we thought was going to be a NEW Kubota MX5400 with a LA1065 and a BH92 with Hydraulic Thumb so everything would be new and I would not have to make attachments like I had to do with our Jinma 354 Smart Trac FEL & BH. Unfortunately Kubota does not have any BH92 or Hydraulic Thumbs in stock and NO delivery date. I did find a very good used BH92 to be shipped to us but now need the Hydraulic Thumb.
I am already going to make a (4) Post ROPS With a 1/8" Steel Canopy and LED Lighting.
Really interested in this DYI Hydraulic Thumb
Thanks much
Len
3,646
2,239
Really interested in this DIY Hydraulic Thumb
Thanks much
Len
* If you go with the Gentech thumb, they can make a pinned mount instead of the weld-on. You'll need to provide them some measurements, but the geometry is better. Things change if you do a quick-tach install.
* The Husco 5002-A1 section is not tapped for load reliefs like the Kubota kit. The tapped section is 5002-A269 and then you have to purchase the reliefs or a plug. You'll need longer tie rods, but these are easy to make from 5/16" and 3/8" rod. If you want to go this route, PM me, I may save you a few $.
* I haven't thought this alternative out fully, but you might use a solenoid valve similar to a third function valve. Then you'd have a rocker or pushbuttons instead of the foot pedal. The solenoid valve would need to be plumbed ahead of the other valve to avoid excess back pressure on the Husco.
2001TLB
L48TLB, 60" EA SSQA Root Rake Grapple, EA SSQA Fork lift
Nov 14, 2021
71
57
Shelton, Washington
Cool!
I look forward to seeing more of your project. The BT1100 on my L48 has a USA Attachments manual thumb. It looks pretty possible to modify it for hydraulic operation, but would take considerable metal working skills to pull off, which unfortunately, I lack. I can melt welding rods, but am not quite where I trust my welding for real work.
Seeing these projects puts a little fire in my belly though.
Doug
Smokeydog
Jun 2, 2020
757
729
knoxville, Tennessee
A thumb will sure spoil you. Once used you’ll never go without. Nicely done modifications.
L35
Jun 13, 2010
683
787
CT
Cool!
Doug
It’s been completed for a few months now. Has come in handy more than once!
thanks to Raleigh for paving the way!
