B3030 white smoke and stalls
Princeton Hayseed
Kubota B3030HST
Mar 29, 2022
Minnesota
I have a 2005 B3030 HST with cab. I have used the hell out of this machine and it has always run well. A week ago I was using the plow and it began to lose power. I would let it idle, then it would run for a while and do it again. Eventually it stalled and wouldn’t restart immediately. I came back to it an hour later and it started up, ran normal for 20 seconds, then died and would not restart. I towed it to a shed and for days it is doing the same thing. If left for a time it will start, dies in 20 seconds then won’t restart unless you leave it sit.
I have removed and replaced the fuel filter. There was a little water in the trap that was slushy. No change. My guess is the injectors, but I have little testing equipment. Any advice would be appreciated.
4,921
I'd drain the fuel tank PDQ as that 'slushy water' HAD to come from the tank. Buy fresh fuel and try again
You 'might' get lucky and after a few starts/quits it'll purge itself and run fine.....
JimmyJazz
1,220
739
Pittsburgh, Pa
Perhaps the fuel line is obstructed .Disconnect it near the filter and see if the fuel runs freely into a receptacle of your choosing for say a minute or so. You will figure it out.
Roadworthy
L2501 HST
Aug 17, 2019
1,649
526
Benton City, WA
The white smoke frequently indicates water in the fuel or compression chamber. The fuel is the cheap fix. The reason to let fuel flow from the tank for a minute or two is to see if it CAN flow freely. It is possible to have a partial blockage which allows fuel to seep through but not enough to sustain combustion. This could be crud in the tank or the growth of algae - which is entirely possible as you've got water there.
Princeton Hayseed
Kubota B3030HST
Mar 29, 2022
Minnesota
Thanks for all the help boys. I started it again and looked at the fuel filter. You could actually watch the fuel drop in the bowl until it stalled. I detached the hose from the tank and it barely dripped. I back flushed with 5 psi air pressure (just to increase flow so the emptying process didn’t take 5 years) and the flow improved greatly. Once the tank was empty I used a small hose drilled into the side of an old plastic container and used a shop vac to apply suction to the mouth of the container. Cleaned up all the gunk. One big chunk wouldn’t pass through the tube. Once done, flushed the tank, hooked it all back up and presto… works perfect.
This was the first time posting to this site.
Thanks again
Nicksacco
Sep 15, 2021
680
388
Bahama, NC
Nice Work!
A true testament to checking the simple things first!
1,418
Use algaecide in fuel to help clean it up
JerryMT
Jun 17, 2017
528
156
The Palouse - North Idaho
You may have restricted fuel delivery as a result of condensed water in your fuel. Disconnect the line that supplies your injector pump, holding a suitable container to catch the fuel. Fuel should gush out. (If your engine has aa lift pump, repeat as you crank the engine over.) If it dribbles or is intermittent the fuel flow is restricted and you'll have to remove the blockage between the end of the line and the tank. Pinched lines, crud in the filter head, at the tank outlet, etc are the usual culprits. Check for bacterial contamination in the fuel tank.
Once you establish a steady fuel supply you should regain power output and engine operability.
Since you found water in the fuel, drain the tank and clean it. In the future try to keep a full tank to minimize condensation which leads to bacterial contamination of the fuel. You might consider treating the fuel with a biocide if you find bacterial sludge in the tank.
