Trying to connect my root grapple to front end hydraulics is extremely difficult due to position of connector next to the arm and for some reason the female collar is very hard to hold back far enough to insert the male end. Is there any kind of tool that can be used to pull and hold the collar back far enough to release the connector balls?
Last year, someone posted a description here of how you can make a simple tool that will accomplish what you need.
It is made by modifying a welders vise-grip type clamp.
It is very simple to make,.....involves just grinding the inside of the clamp a bit to make it push/pull the end of the female collar back.
I modified a welder style vise-grip type clamp from Harbor Freight .
Amazon has these vise-grip type clamps listed for $11.99,...... as "Hobart 770115 "C" Pliers/Welders Clamp".
You will need to modify it!
I would send you a picture of mine, but I am 1,500 miles away until May.
It is a very simple tool and works great!
