Help with part number??
Psychohada
Kubota B2920 w/LA364 Loader,Belly mower & Backhoe
Mar 10, 2022
9
New York
Does anyone have the part number for the front loader control valve for a B2920? Tractor was purchased in 2012 if that helps. Loader is a LA364
4,491
Thank you! Do you happen to know if they're rebuildable?
It appears to be a 2 spool monoblock valve. About the only thing you can service on them is the relief cartridge, spool return components, and the end seals on the spools. If the spools are worn its replacement time. What problems are you having?
Psychohada
Mar 10, 2022
9
New York
I am having an issue with the dump and curl function on the front bucket. I can get it to function, but only with careful manipulation of the lever. It also drips a little bit of hydraulic fluid from the bucket spool. I haven't been able to remove it yet because i've been using it, and it's raining here today. Very low hours on the machine, and I'm the original owner and only operator.
4,491
I would suspect the Rube Goldberg joystick linkages. The leak is a spool seal,.
Psychohada
Mar 10, 2022
9
New York
I hope to pull it apart tomorrow. I'll know better then. Thank you for your time!
number two
B3030HSDC L2501HST
Mar 26, 2021
341
158
Northern Lower Michigan
I seem to recall the early B20 series having a loader won't dump problem.
Most likely the valve is the problem and the OP hasn't used it enough until now .
Warranty?
Good Luck!
