Hydraulic Fluid/Oil
schmellba99
L3800
Jun 4, 2012
95
I know that Kubota recommends the UDT2 transmission/hydraulic oil - but what other brands out there are high quality hydraulic fluids that you guys use on your rigs?
In my old tractor I used the TSC universal, never had any issues...but that tractor was older, had some leaks here and there and I didn't want to put money into good high quality hydro fluid just to eventually leak out. My new tractor doesn't have those issues and it's about due for the 500 hour service. I'm not against the Kubota fluid...just think that you are paying a lot for the orange label on it and not necessarily performance characteristics of the oil itself.
I'm normally a Royal Purple guy, and they do make a hydraulic fluid, but it isn't readily available unfortunately.
RalphVa
738
322
Charlottesville
About the same price as JD's Hy Gard. Paid $27 for a gallon of UDT2, which is about what I'd paid for the Hy Gard.
Not a lot, just short of $7/qt, which is about right for synthetic oil.
I've 2 gallons of Hy Gard left over and was debating whether to get 2 more gallons of it and use it in the B2601 but now seem to have a buyer for the Hy Gard.
3,056
Really depends on IF your machine is HST or not, if HST then I reaaallly suggest you use S-UDT2 ..... but if geared you can use most oils that meet the specs for those geared trannys.
AS for paying for "kubota fluid" - yes - they DO NOT MAKE it themselves - but they get to tell the maker of the OIL, exactly WHAT to put in it.
Now for the fun part - MANY , many oil companies say that their "oils" meet KUBOTA's specs - so, IF you believe the words that are printed on the label on the back of the container - by all means save a few bucks.
There are other oils that people here HAVE used in their HST machines and have had zero problems.
But here is the real question I want to ask ..........
If Royal Purple is (making prices up) 15 bucks a gallon and Kubota's oil (real price) is 22 ........ is it really worth it to buy a less expensive oil? I did not say cheaper oil - just less expensive oil?
10,986
My self tested opinion:
Alternative economic fluid to Kubota SUDT2, is Mystik JT-5.
6,283
Here in Canada, crappytire is $30 for 5 litres, Partsource is $21 !!!
Ironically partsource IS part of Canadian Tire !!!
? 4 NIW... can I 'top up' whatever is in my BX23S, or do I need to drain and fill ?
10,986
Mystik JT 5 will mix perfectly fine with both UDT and SUDT2.
10,986
NIW....
what does that cost you a gallon? Just curious - I know you have using it for years.
It used to be much cheaper, it's $77.99 for 5 gallons so $15.59 a gallon now.
I still have 20 gallons that I bought a couple years ago for $32 for 5 gallons on sale.
Where SUDT2 is about $135 for 5 gallons here.
10,986
One fluid to Never use period is any generic universal fluid, usually stated as 303, or J303 or 303THF
NASTY STUFF
5,187
NASTY STUFF
"Traveller Premium" is the "universal fluid" that TSC sells.
Thus, the "universal fluid" designation would mean that Traveller Premium is NOT satisfactory for Kubota HST tractors?
I use SUDT-2, so am just asking for general information.
7,205
Thus, the "universal fluid" designation would mean that Traveller Premium is NOT satisfactory for a Kubota HST?
Q: What does SUDT oil stand for?
A: Super Universal Dynamic Tractor oil
Universal tractor transmission oil (UTTO) is an industry standard name for a class of lubricants made by many different blenders just like Heavy Duty Engine Oil (HDEO).
SUDT2 is Kubota's registered trademark for their formulation of UTTO. SUDT2 is a low viscosity high viscosity index formulation that has better cold weather performance and water tolerance than all but a very few UTTO formulations. Traveller and Mystic both come up short on that account.
3,056
What he said ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
" COME UP SHORT" well said
3,056
Notice I did not say "unsuitable for use". :unsure:
I liked COME UP short better - as in ....... when the hydro pump needs to be replaced, that 8k makes the bank account ...... come up short!!!! :ROFLMAO: ;)
7,205
My choice of words had absolutely nothing to do with that. It was a simple statement of empirical fact based on published data. The generic fluids simply cannot match the cold flow performance of SUDT2.
When or if that has any bearing on the service life of any hydraulic or driveline compinent is speculative and heavily dependent on other factors.
schmellba99
L3800
Jun 4, 2012
95
It is an HST.
I'm not looking to go cheaper - hell, RP is generally more expensive than most and that's what I use for all of my other oils (Engine, trans, diff gears, etc.) in every other piece of equipment I own.
Was doing some research on using ATF in lieu of tractor hydraulic oil, can't seem to find anything that says that is a bad thing as the weights are the same and trans fluid generally runs a little cooler because of various additives over hydraulic oil.
schmellba99
L3800
Jun 4, 2012
95
I live in Texas on the gulf coast...cold weather isn't a huge concern here, and in the rare times it does get really cold you won't find me tooling around on the open cab tractor. I'm not built for that nonsense.
Heat? Well, that's a different animal - we have a lot of that here.
7,205
SUDT2 is priced where it is because it is an exceptionally high quality cold weather formulation with somewhat unique properties and superior water tolerance. The "best" choice for an HST would be SUFT2. If you are not operating in cold weather and out of warranty UDT or a premium UTTO from a reputable manufacturer is a reasonable alternative.
Universal tractor transmission oils are multi-purpose transmission, final drive, hydraulic, brake, and clutch oils. Regardless of who blends it ATF or ordinary hydraulic oils are not acceptable formulations and will not perform nearly as well.
schmellba99
L3800
Jun 4, 2012
95
10-4, it was just a thought. Between the research, this forum and the answer from RP - UDT2 it is
