2008 BX 2350 D 2950hrs.
Merlin
MS422 Zero Turn, MX5800, BX2350D, Landpride Tiller, Front end loader, Box blade,
Jan 14, 2021
Mideast Florida
I have a 2008 2350D 4x4 wh. a D902 Kubota 3cyl. Can it be swaped out with a 2017 D902 that came out of a VMAC Compressor unit? I'm worried the drive shafts is different?
6,385
Does the 2017 D902 have variable throttle control?
If it does it would be a direct swap, as the rest of the parts will be the same/ or easily swap able.
If not, you would need to swap the governor out of the old motor but everything else is the same.
Merlin
Jan 14, 2021
Mideast Florida
Thanks for your information. Appreciate it.
