If you are going to do a food plot or a garden, run the MMM all the way up and make a few passes where you want to till,, once that is done set your tiller onthe ground and fire up the PTO and let it drop down about an inch or so,, this does several things, it chops up stuff and starts to level out the ground, second pass low range 4WD and go SLOW there are rocks and roots in there and you want to kick them out and not jam inthe tiller,, and on each pass go a little deeper untill she is all the way in. and make several passes back and forth then side to side, and this is of course on ground thats never been tilled before. And yes the more you work/play you are going to find out that BX is a beast for its size. And as always look things over and think about what you are going to do, sit and then think about it again and do it SLOWLY. And the most important thing is to enjoy it
