L2250 Gasket material in hydraulic oil
Hookstownben
Kubota L2250 DT
Mar 5, 2022
Verona NY
Hey guys been reading the forum for a while this is my first post. I have a 1986 L2250. Love this thing my pap bought one brand new in 1986 and I bought one this year.
while catching it up on a serious lack of maintenance I found a bunch of junk in the hydraulic filter. It looks like some kind of gasket. The pictures are the biggest piece most of it was small shredded up pieces. Brakes and clutch both seem to work well.
Previous owner did little to no maintenance. Started working on hydraulics because of water in the system. I’m on my second flush trying to get the white goop out.
thanks
Ben
9,597
Really doesn't look like Kubota's typical gasket material.
It does look like it might be brake pad material.
If it's not leaking and the brakes work I wouldn't worry about it.
Do you have the WSM (aka Service manual) for it?
If not ask and I'll help you out. ;)
Hookstownben
Kubota L2250 DT
Mar 5, 2022
Verona NY
Could definitely use the service manual I have the operators and parts manual from a pdf. Nothings leaking and everything works good. just doing routine maintenance. I found some more and it’s definitely gasket material it’s smooth/shiny on both sides. Looking through the parts manual I see nothing that used a gasket like that.
9,597
Could that be filter paper? Maybe out of the hydraulic filter.
You could very well hit it on the head.
But if it is and it's from a filter on the tractor, all of that material went through the pump, I couldn't see how the pump handled Ingesting all of that, even 1 piece at a time.
3,316
1,734
Does it look like the three-point cover, one of the rear axle housings have been removed or the unit separated at the transmission? They all have gaskets, someone may have had it apart and just left the scrapped of material in the unit.
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
684
292
Herald Calif.
That is definitely brake material. Look closely at the material it has grooves in it.
Hookstownben
Kubota L2250 DT
Mar 5, 2022
Verona NY
It reminds me of these old blue fibrous gasket material.
I thought that at first as well because the oem brake disc is grooved in a checkers pattern. But the stuff is thin. About 1/16 thick,
Hookstownben
Kubota L2250 DT
Mar 5, 2022
Verona NY
I started looking at the breakdowns in the parts manual. It does look like a housing gasket. Some of the pieces connect to make a square shape. The hydraulics work great other than some moisture from being previously stored outside. Looks like someone may have done a brake job and dropped a section of gasket in the rear end. I feel like it would have jammed the hydraulic pump or at least if it went through the pump it would have been much smaller pieces.
I guess monitoring for more is in my future. Clutch and brakes are solid. I’ll pull the filter off after running it some more and see if I keep getting more material.
if it needs brakes hopefully they can wait til spring in New York. But won’t be the first time…my pap has the same machine we did his brakes and clutch 5 years ago should be like riding a bike hahaha
