Hello,
I have a Kubota B2650, LA534 loader, and a Claw Grapple SGC0554 attached. My 3- point hitch (Up/down) operates. The attached grapple (open/close) operates. The loader tilt (L/R) operates. However, the loader up/down) does not. I have cleaned and rechecked the hydraulic hose connections, (A,B,C,D) and hydraulic fluid levels. I have tried moving the control lever in all positions, including float position. The valve lock is unlocked.
I was operating normally and then noticed a light coating of oil spray around the speed control pedal. I discover a hydraulic leak from the 3rd function valve. There was a loose Allen wrench screw on the electric hydraulic solenoid valve unit. I assume the engine fan sprayed the oil leaking from the valve unit that was evident around the pedal. I have not discover any other leaks. I do not know if there is a connection but after moving a tree with the grapple my loader would not lift. I was able to get a slight loader lift, 3-4 inches when I forcibly moved the tractor to a different location. However, currently the loader is on the ground and will not lift up or down. Does this situation sound like a main loader valve issue?
Thank you for any advice.
