product made to clean fuel tank?
lobo
south salem, ny
Anyone have a product recommendation or other solution for cleaning out the fuel tank? It has very light rust and some crud in tank... it's 30 years old.
I removed the tank but really don't want to go the time/expense of having it professionally done. Thanks
Kytim
B6000DT, B7100DT,Snowplow, RM360, Scoop, Cultivator, Carryall,Disk, plow
Aug 14, 2009
848
12
Western Ky
years ago, we used to use short lengths of chain or sharp gravel or some other hard material to clean/de-rust metal fuel tanks. just dont use anything small grained, i.e. no sand! then shake, shake, and shake some more. i've used this technique for all types of tanks, semi tanks on down. of course a round semi tank you can just roll. after knocking the scale off inside, rinse out with a solvent of some kind, no water.
i had a friend that ran an old car resto shop that used an old clothes dryer to build a contraption using the moter,pulleys and asst parts that clamped the tanks inside a plywood box that turned the tank over and over with the chain inside, when taken off, looked like new inside. noisy as heck tho.
2,642
We used to use a couple cups of BBs & a little diesel, then shake till our arms fell off..... worked great on motorcycle tanks, just a quick rinse with gas & it was like new.
We used a coating to re-seal the inside, but I can't remember what it was.
300zx
1979 B7100D, 2009 ZG20, 1991 B2150, 1990 B6200
Dec 1, 2010
445
Forest, VA
Kytim, I have heard the same thing. Either the dryer approach or strapping to anything that will turn it for a while. One guy used a cement mixer, another the back tire of his garden tractor after he jacked it up. Beats wearing out the arms.
John
Kytim
Aug 14, 2009
848
12
Western Ky
The garden tractor is a good idea for small tanks. wish i'd heard that one earlier..
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
I'm a great fan of electrolysis!!
dave
exrceme
b2620
Apr 23, 2012
Ontario Canada
I once stored a outboard motor for 4 years when I came back the tank was rusty inside I took it off and brought it to the shop and filled it with carb cleaner left it over the week end and it cleaned up nice no more rust
lobo
south salem, ny
Thanks for the help. i pulled the float inside the tank and used two 6" lenghts of chain with a gasoline and Seafoam mixture, then rinsed. It came out pretty good and tractor is running fine... would have been a lot better if I had the patience to shake for more than an hour.
Kytim
Aug 14, 2009
848
12
Western Ky
dave
Me too, but i'm not sure about tank interiors unless a sealer is used. Will the iron phosphate/diesel combination precipitate any sediment? chemistry never was a strong suite with me.
