L4240HSTC-3 Turbo upfit-upgrade?
dfixit1
L4240HSTC-3
May 17, 2019
143
17
United States
Wondering if anyone has performed a turbo upfit-upgrade on one of these?
I think the boost would come in handy with my front snowblower on my hilly driveway. It is a interim tier 4 without the catalytic converter and dpmf.
Thanks
tractorX
KUBOTA L2501 DT 5' BOX BLADE 42" FORKS PIRANHA TB 5' BUSH HOG 6' GRADER
Sep 27, 2013
81
79
Rock Spring GA.
Rdrcr
May 7, 2021
671
740
WA
Thanks
I’m not familiar with your tractor or engine. Is it a simple mechanical diesel or is it electronic computer controlled? If mechanical, a turbo can be added without too much trouble. If electronic, as of this posting, I’m unaware of anyone offering ECM ‘tunes’ that would be necessary to control fuel for that setup.
Mike
6,384
Yes you can bolt a turbo on it, but you'll need to rework the fuel injection pump to get anything out of it.
5280GearHead
L3240 HSTC Grand L, L514, Chipper, Grapple
Oct 15, 2024
Denver, Co
Hello, new to the forum here. Looking for some suggestions and guidance to add hp/air to my victim which is a 2012 L3240 HSTC-3 (D1703) 770hrs. my issue is the property sits at 8700 ft elevation where the air is a little thin. Im not looking to do hole shot wheel stands, but a reliable boost of AIR into my orange breathing dragon would be great. Anyone out there make a reliable, proven turbo kit for a D1703, (non dpf, mechanical Diesel)? I read in past years where Mikemoto on this forum had built a turbo kit with an oem RH3F Kubota turbocharger setup on his D1703. Any help to get my Orange Angry Dragon breathing at altitude would be GREAT. <Les>
Rdrcr
May 7, 2021
671
740
WA
Can you take some more pictures of your engine/engine bay? The S2T Performance L2501 Turbo Kit may fit your L3240.
The L2501 Turbo Kit is currently on Back-Order but, is well worth the wait!
Mike
5280GearHead
Oct 15, 2024
Denver, Co
Mike,
Thanks for the suggestion, I’ve been researching the S2T performance L2501 kit and the L3240 is basically identical. Where it gets interesting is getting the compressor pipe over top of the AC Compressor, who put that ac compressor right in the middle anyways 😎.
I think I’m going go ahead get on the back order list. If all goes well by spring the Orange Angry Dragon will have a new attitude and some extra air in her lungs. Thanks again Mike
