B2100 remote hydraulic control lever double acting?
xenophon.nl
32
Netherlands
Hello,
I am new to this forum and new owner of a Kubota B2100 tractor.
I am trying to figure everything out.
I saw some B2100 for sale in the past with a double acting hydraulic connection on the back (so 2 quick disconnect's on the back), but I noticed mine only has one. Is the standard B2100 remote hydraulic control lever single acting? Can it be made into a double acting lever?
8,756
The US models are different than the model's that you all got.
The hydraulics are different, that single port connection on the back should be only one way acting and d normally controlled by the three point control.
There was a kit to add hydraulics, but I can not find the part numbers for it.
It involves an adapter block and then you add control valves to it.
Ask a local Kubota dealer about it, as they might still have one or know where to get one for it.
xenophon.nl
32
Netherlands
The connection on the back is currently connected to a single acting front lift. It is working, raising (and lowering by gravity) if I use the remote control lever (the lever next to the three point position control lever). Not sure if it has any interaction with the three point position?
8,756
Ok, there is a vast difference in controls between different units of this series.
