BX heater install
BX'r
BX2370
Jun 13, 2020
109
22
Sault Ste. Marie, Ontario, Canada
Any reason this wouldn't work?
Redirect hose from thermostat to the heater and run the return back to the water pump.
I 'll add shut offs to bypass the heater in the summer and run the coolant from the thermostat directly back to the water pump.
5,154
That is what I had done to plumb my heater back in the early 2000s when I installed a Curtis cloth cab. I cut that hose and got hose adapters from NAPA to increase the hose size to the diameter of the hoses coming off of the heater itself, and it worked great. I didn't put any shut-offs in the lines because in the warmer months I took the doors off of the cab, and the coolant flowing through the heater core didn't present a problem since the fan wasn't on.
5,791
It'll work but how well ?
The amount of heat you get from a heater core is based upon several factors and FLOW is critical, low flow = warmish, high flow = lots of heat.
fairly easy to plumb and test though !
bird dogger
Vendor Member
Feb 24, 2019
1,712
1,659
North Dakota
Exactly what I did for a heater in my homemade cab. 3/8" hoses run back to the heater where mounted was all that was necessary for enough water flow. How much heat will the heater put out? see Post 15
Depending on the size of heater you choose it can have you sweating in the coldest of outdoor temps. :)
orange crusher
BX 2680
Sep 30, 2017
354
482
ontario canada
I put a tee fitting where you have it marked in the picture. I also installed a 3/8 nipple on the other side of the thermostat housing to replace the hex head plug on that side. Lots of heat so far
bird dogger
Vendor Member
Feb 24, 2019
1,712
1,659
North Dakota
If you google "heater bypass valve" you'll find a few different models (manual, cable or electric operated.)
You can completely bypass the heater circuit or even "feather" the flow to the heater to suit your needs.
BX'r
BX2370
Jun 13, 2020
109
22
Just posting the finished project.
The fittings on the valves were replaced with NPT fittings and the molded 5/8 hose came from O'Rileys , Gates 18777 coolant hose.
Placed an air bleeder valve above the heater .
