Post hole digger with down pressure
MOOTS
MX6000
Jun 27, 2019
2,189
2,718
Canton, Georgia
Is that what this cylinder is for?
This came across marketplace while scrolling this morning. I'm not in the market, but was curious as to what this is for.
Here's the ad, if anyone wants it.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,444
1,740
Kalamazoo, MI
Sure appears that way to me. I've never seen one like that before. Looks massive!
9,956
Yes that is a down pressure setup.
G.rid
L48 tlb, ssqa forks, manual thumb for hoe
Aug 19, 2016
207
17
Oxford, NS, Canada
I don't see how that would add down pressure, unless the lower arms could be locked down somehow.
Maybe I'm missing something 😕
bucktail
Jun 13, 2016
1,276
198
MN
It's pulling on the top link to get the down force.
10,224
I'll take a stab at it.
It looks like the cylinder/ram would limit excessive bounce and maybe provide some downforce. As the ram is extended and the pivot moves in the direction A, the lever rotates around pin B, and the surfaces at C make contact with the hoop. As the auger is going into the ground, the angle between the top beam (top link) and the hoop has to change, so the surfaces C "roll" around the hoop as the ram is extended, sort of like a cam.
Maybe it didn't work that well and that's why Bush Hog doesn't appear to offer that feature any more. I plan on buying a post hole auger soon and will get the SSQA version which overcomes all of the problems with 3-point systems.
hedgerow
437
419
Malcolm NE
Years ago before I had a skid loader and moved to having a post hole digger on it. I had Danuser brand digger with a cylinder to add down force it was a little different than that bush hog but it did help a bunch in tough ground. After you have a digger on a loader you will never go back to a three point digger.
Vigo
B6100, B8200
Jan 9, 2022
595
342
San Antonio Texas
Never seen this before. I once started messing with a little program called Linkage for modeling the movement of things such as this, but my attention span wouldn't allow me to get much use out of it..
