Hello, Just picked up my first tractor. Used L2050 with tiller, brushhog, rake and front end loader. It has 600 hours on it. I was excite to see this forum while doing some research on it.
I have been cleaning it up and fixing little things that need attention but have a few questions that I would like to address. Before someone says it I am shopping for the manuals for it and will hopefully get them soon.
First question is regarding hydraulic fluid. Does this tractor use the same fluid for the transmission and hydraulic system? What fluid do I need to use? Is there a fluid that is not Kubota brand (cheaper and easier to get) that will work sufficiently? I found a fill plug on top of the transmission but there is no dipstick. There is a sight plug on the side of the trans but it has become cloudy from age. I was able to get a pretty good idea of the level looking down the fill plug.
Glow plugs. I understand that I need to turn the key to the left to operate the glow plugs but unlike my truck I do not see any lights that indicate they are on or when I turn them off. I have been just holding it for about 8-10 seconds which seems to work.
Everything works very well for the most part. The only issue I have had is when I brake and steer I sometimes do not have sufficient hydraulic pressure to do both. Similar to my Ford powerstroke under the same circumstance.
Lastly, the seat is missing the cover and padding and is just down to the old school steel shell. I would like to put a new seat on it. Does anybody know of a reasonably priced replacement?
Thanks in advance for any help.
