torch
Here's a video by a fellow who uses a very similar Woodmax brand on the L3301:
There is an angle in the video showing the top link bracket. To my eye, that bracket is heavy steel, but insufficiently mounted. All Kubota's HD brackets wrap over the top and into vertical bolts. They don't rely on horizontal bolts that could be stretched or the casting stripped out. He does mention the issue near the end of the video, and comments on how heavy the bolts are, but a chain is only as strong as the weakest link -- heavy steel brackets and strong bolts are great, but don't address the limitations of a cast housing.
The B4672A backhoe is much smaller, lighter and will apply less force on the tractor than the BH77 that machine is designed to accommodate. Perhaps one might get away without any reinforcement. But if it was my machine, I would want to beef things up a bit. The BH77 subframe might be overkill for the B4672A, but it certainly would be easy enough to fabricate some sort of additional reinforcement between the axle and FEL mount. And if Kubota does not offer a HD top link bracket, I'd be fabricating something for that, too.
(I could not source an original HD bracket for my tractor, and so fabricated my own. Here is how I personally went about that:
https://www.orangetractortalks.com/...need-a-hd-top-link-bracket.46855/#post-408538 )
