Securing extra hydraulic hose
OldcrowP51
Kubota L3901HST, RCR1860 rotary cutter
Aug 18, 2021
52
26
Minnesota
The grapple I got comes with extra hydraulic hose for full tilt.
What are you guys doing to secure it so it doesn’t get pinched or torn from the machine?
Using a bungee cord for now.
4,707
Works for me but I am kind of anal about plumbing. So I would shorten them up and come off the tee at 90 to the right running along the grapple. I would ditch the 90's at the couplers and come straight in with a smaller working loop in the hose. All that exposed hose will get snagged.
7,158
You've done the best thing, it's a bungee cord or cloth covered spring in most cases.
There are spring loaded hoses ( coiled) available but they are stupid expensive.
Yea shortening them is not advisable, because yes you'll use the length up when you dump fully.
5,897
I made a flexible spring with a quick connect to mount to the loader so it's easy to take off and leave with the grapple. The base (circular part) is clamped, and stays with the loader.
5,897
Using a grapple you have to be careful some material doesn't snag the quick attach levers and release one. Then you can get the attachment plates out of time.
Here's a simple solution, a couple of 1/4" holes at the end of each lever.
Chanceywd
Kubota L2501DT BH77 VIRNIG URG60-CT 1950 8N
Mar 26, 2021
638
523
central ny
I used a muffler clamp with a short piece of pipe and then part of an overhead door spring. It is mounted on the cross tube of the loader and stays on all the time. I have that chain link zip tied in place to try for fit and it worked ok for keeping it out of harms way in testing. I have been dealing with carpal tunnel surgery and had the second done feb 7th so no real testing but hoping in a couple moths to give it a work out with my firewood I do each spring. The Spring hook needs a little more heating and bending to finish.
Like others said I think the hoses could be a little shorter, maybe a foot?
Bill
Kurtee
BX2660, BX2680 cab, JD 2032R, Honda 5518, JD X590, JD X739
Oct 3, 2013
319
107
Nicollet, mn
I run my hoses under the pivot bar for the bucket and back up to the couplers. Works for me.
3,673
2,186
I'd weld a metal tang and mount hose clamps to take the strain when your hose flexes.
Right now all your hose strain will be on the fitting which is easy to snap off.
I'd also suggest going with a 45 degree on your couplers instead of the 90's you currently have. Hose sleeve on the loose parts will prevent the rubber hose from wearing and kinking when it rubs.
Lazy Sod
49 hp L-1501, DW 2021, a Europe only model
Sep 14, 2020
Wiltshire, UK
That's a good use for that rubber thing that's useless in it's original purpose of holding the drop arms together. Fairly soon after I bought my Kubota, I replaced the turnbuckle stabilisers with the much better telescopic ones that rendered the rubber thing as surplus.
Why manufacturers persist with turnbuckles in this day and age I don't know. I had a 78 hp Fiat that had telescopic ones when manufactured in 1983!
5,897
LS, it's all about cost and being competitive. On smaller machines those apparently simple things add up quickly and take space that is sometime at a premium.
