Pump for your plastic cans.
5,153
The first time that I have found something that is less expensive in Canada than in the US...
Sold by Amazon... US version $75.33 with free shipping.
Canadian version $69.99 with free shipping.
GrumpyFarmer
4,220
I use a tera transfer pump….I can’t confirm long term durability but I’ve had one for a few sessions now. It works great.
leveraddict
Apr 1, 2019
905
591
NEPA
"D" cell Kero/fuel pump from Harbor Freight $5.00! Same as the others without the fancy handle. Im cheap!;)
5,778
interesting...ad doesn't say if good for diesel though, not even gas...but does say 'snowmobile',but not 2 stroke of 4 stroke....
I just buy mu diesel in 10L jugs, 3 at time. can't lift/carry 20L ones any more. If I used lots of diesel, I'd just use a 45G barrel. I have a $600 proper 'fuel transfer' unit here...used once,collecting dust.
6,903
This is the last paragraph of the ad.
"The Tera Pump TREP03 Fuel Transfer Pump is a multi powered pump using the included wall power adapter or DC clips attaching to your battery providing a 2.8 gallons per minute flow. Easy portability and convenience. Store this pump in a vehicle or garage to fuel your car, pick up, semi truck or other vehicles and equipment. The Terapump TREP03 is compatible as a Diesel transfer pump, Kerosene transfer pump, Light oils transfer pump & non-drinking water transfer pump."
OrangeKrush
Nov 15, 2020
1,044
517
Indy
*Gas Can Not Included! 😳 I'm even cheaper..
Boatman
Kubota L2800, Kubota BX1870
Nov 26, 2016
168
54
Mill Spring, NC, US
I'm cheap too. I bought this pump back in December the fill the hydraulic fluid after having to split the tractor. Worked great for the hydraulic fluid and since then been used for both gas and diesel multiple times. For $16us I wasn't expecting much and was positive I'd be returning it. I've pumped between 80-100 gallons so far.
I will say the hydraulic fluid was slow to pump but it beats standing there with a five gallon bucket trying to carefully pour into a small funnel.
Amazon.com: Ideaworks JB4840 Sierra Tools JB5684 Battery Operated Liquid Transfer Pump, Single, red, Blue, Black : Automotive
xrocketengineer
Nov 14, 2020
820
753
Merritt Island, Florida
I found that same one at the local Harbor Freight store (not on the website though) for 9 bucks. I used it for about 3 years and it finally crapped out. Bought another one, still about the same price and I could not get it to work. Once they are used in fuel they can not be returned. However, HF has a toll free number for that eventuality and they refunded my money . I then tried some ancient batteries on it before scrapping it and somehow it started working!
I previously had bought the Terapump TRF01 for about 55 bucks. The piece of crap started leaking badly at the threaded collar and by the three months of use, it would just leak and it could not pump any fuel.
SteveBX23
LX2610SU; BH77
May 23, 2021
180
305
South Jersey
Has anyone experimented with trying to put some sort of fuel filter in line with that Harbor Freight pump?
3,637
I was wrong . It is on their website now but you have to buy in a store.
Harbor Freight Pump
Thanks for the link! (which states that it’ll be available online after Feb 25)
and says it’s suitable for gasoline also.
I think this might be a handy way to empty a fuel tank.
leveraddict
Apr 1, 2019
905
591
NEPA
Thats the one I use. The hose is not very long but I set the jug on the deck of my BX and fill er up! I do like the longer hose on the one Dusty posted but not the price for basically the same thing.
RalphVa
738
321
Charlottesville
I've a fuel filter. Haven't used it in years but thinking about buying another filter for it and using it to filter the 50 hour hydraulic fluid I remove and put back into the tractor. I've a 12v Northern Tool extractor pump to pump through it. Don't think a battery powered pump has enough ooomph to pump through a filter.
Tried a Mr. Funnel. Have never ever had a water in diesel problem since 1978 in using diesels. What's the use? It just cuts down on the flow of fuel into the tank.
4,257
I got tired of the cans and got a 15 gallon plastic barrel form facebook shopping thingie. Got a HF fuel pump had a coupon so that was cheaper. Around a hundred bucks and I have fuel for a couple weeks one the drum is filled,, the HF pump has a filter in the end of the pick up hose. That paper towel is gone I opened the large bung to fit the hose,, It works pretty well, a funnel inthe small bung allows filling it from the 5 gallon gas/fuel cans
SteveBX23
LX2610SU; BH77
May 23, 2021
180
305
South Jersey
I got tired of the cans and got a 15 gallon plastic barrel form facebook shopping thingie. Got a HF fuel pump had a coupon so that was cheaper. Around a hundred bucks and I have fuel for a couple weeks one the drum is filled,, the HF pump has a filter in the end of the pick up hose. That paper towel is gone I opened the large bung to fit the hose,, It works pretty well, a funnel inthe small bung allows filling it from the 5 gallon gas/fuel cans View attachment 74755 View attachment 74756
I have a bunch of these at work. May have to look into this setup
