I have a BX2816 front snowblower and just broke a fan / impeller shear bolt (probably on a rock from my gravel driveway). I replaced the bolt with a super cheap close fit low grade bolt that I had in the garage. It immediately broke again when I engaged the PTO with no load on it. When I spin the fan / impeller, it freely spins for almost a full turn and then hits against something solid in one direction, and feels like it kind of wedges solidly up against something in the other direction. I don't know the internals of the blower, but assumed that if the shear bolt is not there, the fan should spin freely and not feel like it is stopping on anything after just one rotation. There are no remnants of the bolt, the area around the fan blades is clear, it is not rubbing on anything - just feels like there is a pin or something inside deeper that is stopping it.
I will take it apart, but hoping that someone who knows these might know if this is normal or if something is broken inside. Thanks in advance.
