homemade wood splitter idea. could it work?
gunnersguru
L4701
Aug 12, 2021
17
19
SEMO
L4701 owner . I have a toro 27ton gas wood splitter with a blown motor. could i uncouple the front bucket hoses , make longer hoses to fit and run a splitter . i know it would be slower @ 7.8gpm
5,164
You could, but the real question is does your tractor have enough hydraulic pressure to operate the cylinder to split the wood. You also would want to evacuate all the oil from the piston so you don't contaminate the hydraulics on your tractor. It might just be better to bite the bullet and buy a new gasoline engine for the splitter.
6,323
27t splitter, so maybe 8-10 HP engine, even new, $150-$200 ??
Overall cheaper,easier and better than
buying new hoses..and idiot proof fittings...
time to setup/connect.disconnect evrytime
FUEL to run your tractor
tractor is literally tied to woodsplitter
probably a few more reasons
only 'good' reason to do it...
nobody but YOU can uses YOUR spltter...
3,090
What Jay said - for the time and money, buy a new engine! You will come out way ahead in the short and long run!
6,323
probably buy a 'clone' for half the price and given the low hours it'll be used, should work fine. I've used Princess Auto Honda 'clones' for decades,including commercially used motar mixer. No problems.
7,715
Pick up a Harbor Freight gas engine. I have a Honda 5 HP engine off of a power washer that's just barely broke in, but it's horizontal shaft. I can remember seeing a wood splitter with a vertical shaft engine.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
My Troy Bilt has a vertical shaft with the pump attached to the bottom.
The bottom hydraulic hose is seen here coming from the pump.
Stomper
2017 L2501. Landpride Mower. Farm King Snow Blower. DIY Root Bucket grapple.
Jun 30, 2017
240
Northern Canada
I agree with buying a new engine for it as well, for all the reasons above, and also, why put unneeded wear and tear on an expensive tractor engine when you put it on a $300 throw away engine.
6,323
there's another 'minor' problem with couple to your tractor.....
EVERY time you disconnect, you'll LOSE hydraulic oil !
The splitter cylinder will be full(say 3 quarts ?),now your tractor is DOWN 3 quarts, THAT probably isn't good fo the tractor...
7,344
Absolutely. No need to disconnect the loader - just put a quick coupler on the loader power beyond line and use that to run the splitter the same way Kubota runs a backhoe. A hundred dollars will hook it up. I run mine on a L3901 @6.8 GPM just fine.
3,581
Why not even consider a HF engine?
Most folks have had good luck with them.
I was going to suggest the same thing... I haven't personally used one, but I know several people who have, and I've heard no complaints.
3,581
Never saw a log splitter with a vertical shaft engine. o_O
I'd like to see a pic of that.
3,581
No, I can see the full pic, just not enough detail- looks like just a black box. Having never seen one like it before, I couldn't make out the muffler, air cleaner, starter pull, etc..
After seeing pics on the website, I got it now.
