Has anyone had experience with bearing replacements on these tractor engines.
I have taken out the pistons, no scuffing and within spec, but I need to replace worn rings.
Bores are within spec.
The rod journals mic up fine but the bearings are worn so need replacing.
The main bearings cant be checked on these unless I pull the whole motor.
Do the main bearings hold up better than rod bearings, if anyone has experience with this doing an entire crank?
Its a much bigger job to replace mains as well, because I would have to pull it off the tractor and especially didn't want to, seeing that the rod journals are in good condition.
Also I need a full sets of rod bearings and piston rings. Does anyone know of any good quality aftermarket suppliers of these.? I live in Australia and there are Chinese sets available but I haven't dealt with them so I am wary because I don't know the quality.
