Elliott in GA
If you review the video, he differentiates between heavy use equipment (construction equipment) and compact tractors. For construction equipment pins and bushings, he acknowledges the value of moly, but compact tractors do not experience these types of loads/forces.I didn’t see that at all.
Mike Wiles (AskTractorMike) and I communicate directly from time to time. He’s a really really REALLY nice guy and very knowlegeable about tractors and such. By his own admission…in his opening statement …he does NOT know about grease.
In the video he introduces the president of AET, the seller of LubeShuttle, a guy named “Wes”…who is a SALESMAN for the LubeShuttle products and Mike refers to him as an “expert” on grease.
He is NOT an “expert” on grease. He does NOT ”manufacture” grease …as he CLAIMS in his comments …(such as when he states, “when we make grease…..yadda yadda yadda …. centistokes....yadda yadda yadda.) He does not “make” grease…he sells grease in tubes that fit his LubeShuttle product. His primary interest is in selling you a LubeShuttle and thereby boxing-you-into buying his LubeShuttle Cartridges.
Further, throughout the video “Wes” contradicts himself, first by tossing out phraseology with which he hopes to Impress the listener with his use of “buzz-words”…. then by misapplication of those very phrases. In particular, Points 3 and 10 and subsequently, he says the “type” of grease you use is “not that important”….(the differentiation of which he refers to by PRICE)….then he goes on to say that there ARE ACTUALLY valid reasons for different grease thickeners (such as Lithium, Calcium, Moly, Poly-urea)….and then acknowledges that MOLY is BEST for PINS and BUSHINGS but NOT for BEARINGS. Then (item 10 and subsequent) he emphasizes that after all the comments in which he says it’s NOT IMPORTANT for “compact tractors” what you use…. he emphasizes to “follow the manufacturers’ instructions” as to what specific type grease to use.
He contradicts any notion that he is an “expert” on greases when he promotes poly-urea/synthetics by “why it’s used in sealed bearings”….WHICH ARE NEVER GREASED because they are “sealed” not not serviceable by operators…. the implication being that if it’s good enough for sealed-bearings that never get greased it must be ”best” for tractors, skid-loaders, balers, etc… … THEN he Completely negates his own recommendations by stating it is ”not necessary for compact tractors”.
HERE is what he DOES say which is CORRECT: Lithium is probably the most commonly used general purpose grease. Moly should be used on pins/bushings such as on FELs. Do NOT MIX different types of greases. FOLLOW your Mfr’s recommendations.
Kubota says “general purpose” on tractors and ”Moly” on FELs. DOH.
Just as a point of comparison, the values of 5% moly and poly urea grease in terms of Load Wear and Timken are approximately the same if you look at their spec sheets. You can also buy 5% Moly for heavy industrial equipment with much higher values (and extreme price) due to the additives package - not the Moly.
Use whatever grease or greases you want; I feel comfortable using just Poly Urea on my compact tractor, 3 pt. mowers and related equipment.
