3301 drawbar hitch .
Chanceywd
Mar 26, 2021
801
787
central ny
anyone have the dimensions of their drawbar ?
thanks
animals45
So After a couple searches I found my draw bar where I put it so I could find it easily.
I believe my L2501 is the same as your tractor just a different engine? It is 23-11/16 long x 2 x 1-1/4 thick.
3 holes appear to be 13/16" at 1-5/16, 7-7/8, and 14-3/16 centers. 4th hole is 11/16 located at 18-3/8 center and the last hole is 1" located at 22-3/8 center.
The picture i hope shows you the layout I described if I errored when I wrote any of it. I switched it end to end before putting the tape on it.
Bill
Chanceywd
Mar 26, 2021
801
787
central ny
No dimensions but they are inexpensive and I would suggest you just buy one:
I looked at your link Dan, not a bad price or worth trying to source a piece of steel if you don't have the means to drill those holes. I just thought I would take the time on a cold day with little ambition to measure mine for animals45.
How did your wheel spacers come out?
Bill
Chanceywd
Mar 26, 2021
801
787
central ny
Bill
I also checked and apparently mine isn't the same drawbar. Mine is TC 220-29710 and lists for $183.46. Don't know why so different but maybe disregard my post. So much for them being in the same family.
Bill
Chanceywd
Mar 26, 2021
801
787
central ny
Bill
Bill
But to add more to the mix I looked at both models on messicks and they both take the same draw bar bracket, but the draw bar is different. So I would assume it is only in length or hole size?
3,741
2,312
Ya I should have clarified that titan implements brand is made in TN. Titan attachments is the Chinese stuff. Not sure what you’re looking at.
I’ve looked at some titan implements stuff and honestly wasn’t impressed (even versus the Chinese comparative equivalent). Not saying all Chinese stuff is bad and worse than American stuff. Both will certainly meet your need…though I personally still avoid Chinese because I rather support American made…made in China is mainly to keep operating costs lower and profits higher.
That said, as already mentioned, that tractor isn’t rated to pull 2k Lb+
To further complicate things, Titan Attachments www.palletforks.com is headquartered in or near Memphis while Titan Implements is in Decatur, TN, about 150 miles away.
6,973
Bill
I would not have guessed that. With the L01's its usually the 4901 that is the odd man out.
animals45
L3301l
Apr 22, 2021
282
94
Mabie CA
Thanks for the info. I'll be checking with my steel guy next time I'm in the big city . Wheel spacers arrived & installed with no issues . Backhoe in on right now , but rumor is weather next week so I'll probablly put the snow blower on this weekend .
thanks again for the info .
animals45
HVACRoger
2021 L2501 Loader, Backhoe, LandPride Grapple, Tiller, Forks, Quick Connect
Dec 20, 2021
174
96
Wilson, NC
Not trying to steal your thread animals45, I had posted earlier about the Titan 3pt hitch in your thread, figured best place to follow up with some that responded. I did call Titans (Tennessee) customer service line, a little wait but guy was great, said they are slammed with orders/ business. They make several versions of the hitch including a light weight (20lbs) up to the 50lb HD model. Long story short I purchased ($199) the HD model. Supposed to receive Feb. 3rd, will update on what I think about it after pulling some trailers.
JimmyJazz
1,273
805
Pittsburgh, Pa
“Titan” is kind of confusing. There’s a Titan that is https://www.palletforks.com/?gclid=EAIaIQobChMIhP_f_4PM9QIVBLKGCh0DxApQEAAYASAAEgLeIvD_BwE
And then there’s a Titan that is https://www.titanimplement.com/
They ain’t the same. Titan Implement (the second website) is the Tennessee made stuff.
Titan Attachments (I believe but am open to correction) are purveyors primarily of fine Chineseum.
Not sure which you were looking at but if country of origin is a concern, conflating the two may lead to disappointment of a missed opportunity or disappointment of getting what you ordered rather than what you expected.
I have pallet forks from Titan Attachments and the welds look like they may have been performed by Helen Keller. Probably made in China. The prices have recently been raised. I like mine. Heavy duty. Got them a few months ago. I thought they represented good value.
