la 344s fel quick attacht
diesel4x4
bx2200d
Aug 10, 2019
Jessup
hello i have a la344s fel i want a set of pallet forks for it . when you flip the 2 levers and remove the bucket i want the fork attachment to put back on does any one have a part number for these ? is the attachment a standard size ? same as a skid steer ? any help would be appreciated thanks dave
OrangeKrush
Nov 15, 2020
1,047
515
Indy
Yes it is a standard size, here's mine on a BX 2680. I think the model # is PFL1242
diesel4x4
bx2200d
Aug 10, 2019
Jessup
thank you very much
4,240
If you can flip two levers and remove the bucket it has a Skid Steer Quick Attach (SSQA). That’s a standard system well beyond just Kubota. You can attach any SSQA implement; forks or anything else. Which of course means you can attach huge implements designed for 100 HP CTL’s your machine couldn’t even pick up, much less use. Only point being when looking for loader implements in general, look for SSQA compatible and make sure the implement specs and weight match up with your machine’s capabilities. I believe you’ll find a very wide variety of options available for most implement types.
The PFL1242 suggested by OrangeKrush should be a good fit for your machine.
