What's interchangeable Model wise
BonnySlope
BX2380FEL, Add-A-Grapple, Box Blade, Rake, Rear Blade, HR12 Tiller, Flail Finish
Apr 11, 2021
140
122
NW Oregon
Hi for those of us who are looking for tires and wheel for a change over set(2 sets) Ag. and field and grass aka turf, something with good traction but weight is distrusted over a wide tire patch with more weight capacity ( like for me the B7100) and not just traction bars like on a agriculture tire. I'm also realizing I may have to do some tire grooving to open up pattern. I have two mounted rear Good-Year XTRA Traction, Terra-tire, which are 27 X 8.50 2 ply probably older then a lot of us :) and would improve with a little grooving. The problem being these came with tractor and until I tried to inflate them didn't realize all I really was getting was a extra set of wheels:confused: Oh well, tried tubs from local area tire shop to purchase and install tubes for me, lets just say Bad experience I return to see they had mounted New tubes in tires and one never should of been. It split side walls and in these in won't hold air. I did ask why I wasn't contacted or given choices. Lets end this part by saying Last time.
Sorry, To the point What Models wheels are inter changeable with each other like the B5100 with other 7100 or LX and BX models I guess a wheel spec chart would work. I have, run across a chart to convert over to radial tire sizes but not a 27 X 8.5 or older models to fit my wheel size. They list tire size in owner/operation manual and I've yet to come across it in Kubota Service manual what wheel sizes are.
BonnySlope
Apr 11, 2021
140
122
NW Oregon
Here's the Field tire I'd like to find in a 4 ply
6,404
The WSM for the B7100 lists the following tire sizes for the 4WD models:
AG:- 6-12/8.-16 (Goodyear) or 6-12/8-16 (Bridgestone)
Turf: 20.5 x 8 - 10/29 x 12 - 15 (Goodyear)
The B6100 used:
AG: 6-12/8.3-16 (Goodyear) or 5-12/7.2-16 (Bridgestone/Goodyear)
Turf: 20.5 x 8 - 10/29 x 12-15 (Goodyear)
If you are asking about rim width it would match those tire sizes.
BonnySlope
Apr 11, 2021
140
122
NW Oregon
There are two sets of wheel sizes - one for the turf tires, and one for the ag tires. The tire dimensions are here: https://www.tractordata.com/farm-tractors/001/2/7/1271-kubota-b7100-dimensions.html
The rims size for turf tires would be 8x6 in the front, and rear 15x10 afaict.
Hey sorry for spacing out or getting distracted, I believe what I was trying to say was looking for Turf/field tire with a similar tread layout of my example and lug pattern and being interchangeable. I have the second set of rear wheels (tire in pic. with that good looking pattern design is the one I mentioned of being rotten on the sidewalls, but like to fine without having to go extreme in cost) and just one set of fronts which look like a diamond block that kind of looks like something I've see a 2WD lawn tactor and they usually have a low weight rating
Thanks for link
BonnySlope
Apr 11, 2021
140
122
NW Oregon
The B6100 used:
Thanks for reply and info. Do all B series have same lug nut spacing?
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
117
102
Lopez Island, WA
The B5100 through B7100 all had 4 on 4" bolt circles in front, and rear wheels are all 6 on 6 circles.
- Bart
Biker1mike
Jan 11, 2022
1,174
1,274
Gallatin, NY USA
Bart,
I am sorry. My mathematic mind thought B6200 was between B5100 and B7100.
I did not know that it is more like this.
Series:B5100 ←B6100→ B7100
B6200
I defer to the master and will try harder in the future.
BonnySlope
Apr 11, 2021
140
122
NW Oregon
Bart and others, well I finally made a decision on rear turf tires and went with these "BKT LG 306 Turf Lawn & Garden Tire - 27X8.50-15 LRB" after seeing a real photo and reviews
BonnySlope
Apr 11, 2021
140
122
NW Oregon
Well tires arrived and they look good. Just finished prepping wheels with some rust buster by Rustoleum and a coat of paint/primer. Going to mount tubeless first and save tubes that I purchased for old weather checked turf tires that were mounted by once used tire shop. Wheels look fairly good with no noticeable damage to bead area.
Not sure how long tubes will sit around or should I just mount them on the tire now?
