I have a Kubota MX5200 4 Wheel Drive with a 4 Speed Manual Transmission. I need to replace the clutch & was trying to get a work shop or service manual before I begin. Any help with pointing me in the right direction would be greatly appreciated.
I don't see it at Kubotabooks.com. If you have a good relationship with your dealer, they may give you a download on your thumb drive.I have a Kubota MX5200 4 Wheel Drive with a 4 Speed Manual Transmission. I need to replace the clutch & was trying to get a work shop or service manual before I begin. Any help with pointing me in the right direction would be greatly appreciated.
The MX5100 manual is available from manulslib. Might be close enough for your purposes. Changing a clutch is pretty basic.I have a Kubota MX5200 4 Wheel Drive with a 4 Speed Manual Transmission. I need to replace the clutch & was trying to get a work shop or service manual before I begin. Any help with pointing me in the right direction would be greatly appreciated.
Do you have a loader?When I bought my LX the dealer sold me the WSM for $15 on a thumb drive. It would have been over $100 if I wanted a paper copy....
I just got the tractor WSM. I only the the operators manual for the loaded. was not worth the $15 to me for the WSM for the loader.Do you have a loader?
If you do check if the dealer also provided you with the loader WSM as the tractor WSM wont cover the loader and the tractor WSM hydraulics will be confusing if dealing with a hydraulic issue on the loader.
If you have a loader also ask for the Loader Assembly instructions. Usually this is where you find instructions for rear remote installation and 3rd function installation.
I hope you never need it.I just got the tractor WSM. I only the the operators manual for the loaded. was not worth the $15 to me for the WSM for the loader.
Probably never will as all the hydraulic vales are covered with the tractor WSM. The rest of the loader is all hard parts that likely are faster and cheaper to replace as a unit than to rebuild. The cylinders are not anything I need a manual for to ever replace a seal on...I hope you never need it.
I do not know the LX series so I accept your statement that all loader valves and power beyond circuits are included in the tractor WSM.Probably never will as all the hydraulic vales are covered with the tractor WSM. The rest of the loader is all hard parts that likely are faster and cheaper to replace as a unit than to rebuild. The cylinders are not anything I need a manual for to ever replace a seal on...
Thats how it is, they did a good job with the LX series.I'm still trying to find a LX WSM, the dealer is tip lipped about the manual.I do not know the LX series so I accept your statement that all loader valves and power beyond circuits are included in the tractor WSM.
That is not how things are on B's, L's and M's I am familiar with
Do you still have a wsm?I sent a direct message requesting your email, I have what you need.
