Im thinking that I may be looking for a new one, the old USSC forced hot air furnace (20 + years) is in need of being replaced. I have noticed the burn times decreasing, and temp control is getting almost non-existent. Yes I have replaced the seals around both doors so that not the issue, and untill I take it all apart ( sheet metal) well then I think I might find a bad weld letting enough air in, so it run's away so to speak.
Anyway there are a lot of wood cutters and burners in here. So if you have a newer unit lets hear and see it, and the good and bad of it. I might even put in a boiler cause I have hot water heat so let me know about them too. And as much as an outdoor system might work better there just aint enough in the piggy bank.
