Thumb Thoughts (for me on a BT900)
Nicksacco
Sep 15, 2021
696
408
Bahama, NC
Hi All-
I'm considering a thumb purchase for my backhoe. I think it will add some value to it since I could actually "hold" things such as logs, or brush. But also I'm not in a hurry so I'm watching videos and doing some reading on adding thumbs - both manual and hydraulic.
So if you feel inclined to jump in, discuss how you use your thumb, what type it is, the brand, did you do the installation, I know it would help me and others who might be contemplating it.
Personally I love machinery, but I have to temper that with the practicality of use. I am a hobby guy and not a professional operator. But as we know, tools make a huge difference when you're trying to get stuff done. They can make a difference between a 3-day job and a 1-day job eh?
2,897
1,586
I installed the Titan weld-on manual thumb on my BT900. It works well for picking up logs etc. and snaking cedars out of brush, for example.
But (there's always a but)
1 Once you've folded it down it gets in the way of digging. A while back, I was getting rid of a double sweet gum tree. I started diggin g out the stump, but then the tree trunks were in the way. I unfolded the thumb and used it to pull the stems out of the way. But when I resumed digging on the stump, the thumb dug in the ground first, so I had to re-stow it until I needed it again to pick up the stump.
2 The stow/un-stow is inconvenient and potentially dangerous. It's handy to always have the thumb available, but the third leg is a separate piece that stows inside the other two and one of the pins holds it all together. The natural temptation is to use a finger to see when the holes line up, but if something slips . . . Also, that leg has to be oriented the right way and I always get it wrong at first. I could probably paint marks on it.
It might be possible to modify this one to hydraulic, but I haven't had a chance to study it yet. There's also the issue of whether there's enough room for 2 more hoses to pass through the boom wrist area, or whether those hoses would just dangle. I've thought about a diverter mounted on the boom, so only a wire would need to go back to the controls.
So, my vote is thumb - yes/hydraulic - yes.
After writing this, it occurs to me that finding a different way to stow the third leg would improve my experience.
BXHoosier
BX24
Jan 21, 2018
487
567
Indiana
I had a manual thumb on my BX24. I sold it and built a hydraulic thumb that is way more user friendly. Any thumb is still better than no thumb.
kubotafreak
Sep 20, 2018
1,049
394
Arkansas, US
Hydraulic thumb all the way. One of those things you don't know how you got along without it.
loggin
MX4700
Sep 4, 2021
103
36
canada
Hi All-
If you can afford it, get the hydraulic thumb!!! It sure beats climbing off the machine to do adjustments to the mechanical one. Also when picking up things in a pile , such as logs or stone, it is much easier to get the thumb to the correct angles needed for secure pick up. You will never regret getting a hydraulic thumb!!
Just my suggestion.
2,897
1,586
I had a manual thumb on my BX24. I sold it and built a hydraulic thumb that is way more user friendly. Any thumb is still better than no thumb. View attachment 73007
Nice job! You've incorporated a couple of things I like. First, I think the best pivot point is at the bucket pivot, by using a longer pin. But that requires a custom fit on pin size and span across the bucket. The Titan I bought is a universal fit, so there is some compromise there.
Also your cylinder geometry allows the thumb to fold back far enough to be out of the way when digging (mostly). Titan makes a hydraulic version of their thumb, but it just replaced the third leg with a short cylinder. When fully retracted, the thumb still sticks out at nearly 90° so it's in the way for digging.
I'm curious. Do you have a pressure relief on your thumb hydraulics? It looks like you're using one of your remotes. Seems like some folks are concerned with over pressuring the thumb if they curl the bucket too hard, and vice versa.
BXHoosier
BX24
Jan 21, 2018
487
567
Indiana
The thumb is controlled by my homemade remotes valve. The valve doesn’t have a relief valve. The thumb has more power than the bucket curl so I always curl the bucket against the thumb and never the thumb against the bucket.
5,080
Hi All-
I had a Ford TLB WITHOUT a thumb for 33 years.
I have now had a Kubota TLB WITH hydraulic thumb for nearly 3 years.
I am 81 now, ....... obviously will never be without a thumb again!
Crash277
BX23S
Jan 17, 2021
844
621
I wouldn’t own a BH without it. After I get my hydraulic top link, a hydraulic thumb mod is next on my list.
Nicksacco
Sep 15, 2021
696
408
Bahama, NC
Wow!
Thank you all for the great responses.
There are a few things I hadn't considered - like overpowering the bucket, dangers of losing a finger, Titan brand @PoTreeBoy ) and making my own (@BXHoosier - Would you consider sending a few more pics and talk about the build and controls?)
Hmmm, I kind of figured that the hydraulic would be the way to go.
I've seen a foot operated version somewhere where a person added a valve to the rack inside the BH housing (see pic).
I was thinking if I could get a valve from a BT900, I might be able to sandwich another.
I wouldn't need to worry about where to get the hydraulic fluid. Anyone done that?
Other than that, I've seen diverter valve setups - but they look unnecessarily complicated.
Is a foot control common practice for a thumb?
2,897
1,586
I learned something too. BXHoosier confirmed a thought I've had about the over-powering issue.
I think the foot control is fairly standard on factory installations, especially excavators. But heck, if the control was anywhere within reach, that would be great. Modifying the factory valve gets pretty expensive if you buy the parts from Kubota. And even though the parts show to be available, I've found that's not always so. Maybe you could find a used valve.
AFAIK, the factory never offered a BT900 thumb. Anybody know otherwise?
BXHoosier
BX24
Jan 21, 2018
487
567
Indiana
Here’s my thumb build thread. Lots more pictures.
2,897
1,586
Nice work. I remember when you first posted it. Maybe it'll inspire me to act.
loggin
MX4700
Sep 4, 2021
103
36
canada
Wow!
Here is a link to some information of a factory thumb install for a BH92 that might help a little. I know it's not the same as yours but possibly something to go by..??
Hope this helps!!
Donystoy
Dec 10, 2013
594
249
Binbrook, Ontario
Fabbed up my thumb a few years ago. It is manual but designed to accommodate a readily available hydraulic cylinder. Before folks comment, the thumb pivot pin is captive on the opposite side so it turns within the dipper when using bucket. Thumb stores completely out of the way without any interference.
2,897
1,586
I like the way it folds up close to the stick.
Nicksacco
Sep 15, 2021
696
408
Bahama, NC
Outstanding!
Thank you all for your responses and ideas.
I've seen @Wildfire videos and should've figured he'd be on this site!
I've looked at all the links you've sent and am impressed by all the creativity and such.
We do love our tractors, don't we?
