Hello All,
I am in need of some guidance on where to look or what could be wrong,
I have a 2019 bx23s bought new in Nov of 2019 with 197 hrs on it, I use the white diesel additive in my diesel during the cold months.
A week or so ago, I started it up to let it warm up to move some snow, it started up fine,
I then went to shovel my entrance deck while the tractor warmed up (it was around 15* out), while shoveling I heard it start running rough and then it shut off,
I noticed a little oil on the garage floor about the size of a quarter, wiped it up, tried to start the tractor again and it would turn over but not fire,
after a couple of attempts my first thought was fuel filters so I decided to replace the fuel filters, just did that today, (that rear one is a bugger).
I turned the key on to fill up filters with diesel for 30-40seconds and checked for leaks there were none and the fuel in the filters looks good, anyways I tried firing the tractor up it started , but was blowing out grey exhaust, then it sputtered and died,
I went through the purge process again and same thing happened, ran roughly, grey smoke then died, then I noticed another teaspoon size drip of oil under the tractor,
it’s towards the front right side between where the oil filter is and where the steering knuckle joins the front axle and steering wheel.
Any help on what to look at or for or constructive thoughts would be highly appreciate. Thanks
