Just purchased a used M6800 4wd and am using it for the first time. To the left of the seat on the floor there is an H pattern shifter allowing you to select reverse ,neutral and low and or high if moved to the right side of the shift pattern.
The info I can find says this model has either a power or synchronized shuttle.
Transmission.
If I use the clutch to shift into any of those selections the handle moves all the way forward or aft and the tractor moves in the appropriate direction. But if I use just the shifter without the clutch the handle will move but not as far. The tractor will move in the direction selected but I have to hold pressure in either direction to make it move.
Is this how this is supposed to operate or should the shifter engage fully like when using the clutch?
Transmission.
