At roughly 80 hours I noticed an oil leak dripping from the vicinity of the front of the engine. I immediately feared the worst but a little searching of the archives turned up a thread about loose hose clamps on the hydraulic oil cooler. Sure enough that was the culprit. The bottom worm gear hose clamp was barely tight enough to contact the hose and the source of the leak. Dripping at the rate of about one drop per second. The upper one was a little bit tighter and not leaking but way looser than is my practice. I snugged them both up and cleaned up the oily mess. Keeping my fingers crossed....
