Top portion of my radiator cracked this past weekend. I am calling around to see if this can be fixed but am not hopeful of that. Does anyone out there have a good used radiator on possible a "parts tractor" they want to get rid of?
What did you end up doing with the radiator? Mine just broke so I'm looking for fixes nowTop portion of my radiator cracked this past weekend. I am calling around to see if this can be fixed but am not hopeful of that. Does anyone out there have a good used radiator on possible a "parts tractor" they want to get rid
If you have a radiator repair shop nearby you might show them your and see if they can repair it. What actually happened to it? Did the tank separate from the core?What did you end up doing with the radiator? Mine just broke so I'm looking for fixes now
One of the bottom tabs that goes in the rubber grommet brokeIf you have a radiator repair shop nearby you might show them your and see if they can repair it. What actually happened to it? Did the tank separate from the core?
Thank youPremium Used Radiator fits Kubota M4900 M5700 M4900 M5700 3A231-17100 H3A60-17100 3A611-17100 H3A20-17100
Radiator for Kubota Tractor(s) M4900, M4900, M5700, M5700. Replaces Kubota OEM Number(s) 3A611-17100, 3A231-17100, H3A60-17100, H3A20-17100.www.tractorpartsasap.com
If that radiator has a brass tank at the bottom a radiator repair shop should be able to braze a pin on the bottom so it would hold the grommet it the mount hole.One of the bottom tabs that goes in the rubber grommet broke
